Question about Chicago Pneumatic CP864 Dual Action Air Sander
On a cp864 the throttle is wide open ,, wont shut off
The throttle wont shut off i think i nbeed part# 124233 where can i get it?
  • 165 Answers
Http://www.airtools.com/catalog/ItemListView.aspx?id=148 try this
Posted on Jul 07, 2009
Will bad throttle position sensor keep jeep GC inline 6 from starting?
it can. especially if it thinks its wide open throttle. try spraying b-12 carb cleaner in the throttle and see if it will run for a sec? if so its a fuel issue. id change sensor anyway for the code and see if it runs
Sep 13, 2014 | Cars & Trucks
I have a 2012 craftsman mdl 316.711970. I follow all maintenance requirements. It will only starts when the choke lever is in position 1. It takes forever to prime it cause the primer button doesnt pop...
I don't think so either. I think you have crud built up inside your fuel tank, and it needs to be thoroughly cleaned inside, Your carburetor may also need to be thoroughly cleaned inside.
Jul 29, 2014 | Garden
I think the accelerator for vento scooter is stuck and when it shuts off makes a weird noise
You should know it if the accelerator (throttle) is stuck. If the throttle moves freely and the engine responds, it's not stuck. If the engine doesn't respond to input from the throttle it needs to be thoroughly checked from the throttle assembly on the handlebars to the carburetor. A corroded, kinked, or frayed cable can cause the throttle to stick. DO NOT RIDE WITH A STUCK THROTTLE! If it does hang wide open, hit the kill switch immediately and sort the issue out before trying to start the scooter again.
Jan 06, 2014 | Motorcycles
My briggs and stratton engine throttle cable and throttle body wont engage,always wide open
Are you sure it's not a new style Briggs that uses the 'throttle cable' just as a shut off? Many new mowers on;y start and run at High Speed
Jul 05, 2013 | Briggs & Stratton Garden
2003 Mitsubishi lancer 2.0 ralliart. Complete loss of power under wide open throttle between 2,000 - 3,000 rpm. Car idles fine and continues accelerating after 3,000 rpm under wide open throttle just fine....
oxygen sensors buddy, and there is two of them. one above the engine and under. you have to cut it enough to where you can splice and re wire another sensor on.
Feb 23, 2013 | Cars & Trucks
My cp 864 dual action sander needs part #KF-124233. Is it available?
You could buy it from :-
http://www.toolsource.com/valve-kf124233-p-74658.html
Click on Add to Cart and then Purchase the Amount.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 17, 2010 | Chicago Pneumatic CP864 Dual Action Air...
Merc 75 4 stroke turns over but wont run
carbs, are gummed up. Pull the carbs and clean em, you'll be up and running in no time. The gas they sell now days, it don't take long for it to varnish.
Jul 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Throttle Cable Stuck Wide Open?
you need to re coil the spring or replace it for it to pull back in to poistion
Feb 12, 2009 | 2003 Yamaha YZ 250
Chicago Pneumatic CP864 Dual Action Air Sander Logo
698 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
