Question about Amana Dryers
Dryer lights but turns off within minutes
Dryer will ignite than turn off within minutes. It attempts to ignite again but doesn't. If it does it agin will turn off.
  • SAM0071 Feb 28, 2009
    It worked, thanks
    President:
  • Amana Master
  • 2,651 Answers
Most coomn issue witha unit lighting the first time andthen consecutive lighting the glow coil "glows" but doesnt ignite, soundslike a bad set of valve coils.Located atop ofthe valve body itself, simplpe enough to change and cost about $25 part number 279834
Posted on Feb 27, 2009
My Cadillac cts 04 won't start... Every time I turn the key it won't even turn over... But the light that shows a car with a lock on it blinks what do I do
Sounds like the anti theft system is active m try this process. Turn the key on. Do not attempt to start. Wait 10 minutes. Turn key off. Turn key on. Wit for theft light to go off. Now attempt to start.
Oct 25, 2016 | Cadillac Cars & Trucks
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
Oct 28, 2014 | Maytag MDE2400AYW Neptune Electric Dryer
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 08, 2012 | 2000 GMC Yukon Denali
Reset theft system in 02 Buick Rendezvous
Just turn the key on, if that doesn't reset it you have a failed part and will need the help of the dealer
Jun 16, 2012 | 2002 Buick Rendezvous
Ignitor is lighting but silinoid is not opening to let gas through.Roper model # RGS7646KQ3
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
I hope i have been able to help you fix your dryer,
GENE
Sep 17, 2011 | Dryers
I need to program a new fob. am reusing the old key! can you help?
  1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
  2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  3. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  4. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp 3 times.
  5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
  6. Turn the ignition to OFF and remove the key from the ignition switch.
  7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
Mar 30, 2011 | 2006 Pontiac GTO
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Starter will not engage anti theft light is on it is a 2005 cobalt
I found this on a website try this
1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator
light on the dashboard will stay on for 10 minutes.
2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN)
position. The indicator light again will stay on for 10 minutes (Do not remove the key.)
3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON
(RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.)
4. When the light goes off the third time, the new key is programmed into the computer and will start
the car. Remove the key and then re-insert it into the ignition lock and start the car.
All previously stored codes will be erased. To stop the process at any time, simply remove the key and use
an existing key to start the car.
Mar 25, 2009 | 2007 Chevrolet Cobalt Coupe
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you an Amana Dryer Expert? Answer questions, earn points and help others
