Question about Canon Rebel XT / EOS 350D Digital Camera
Camera does not fire external flash
I have a speedlite 580ex II flash and a canon rebel xt camera. When I fire the camera, it communicates with the flash but the flash does not fire. The reason I know that it is communicating with the flash is because when I press the shutter button, it not only wakes up the flash, but sends out the pre-lighting. However, the flash will not fire. What could be the problem?
  • 4 Answers
Also be certain that the flash is screwed onto the shoe as tightly as possible.
Posted on Feb 28, 2009
  • 3 Answers
Is it in manual or auto modes (camera)Try resetting the camera back to factory defaults as a first step.
Posted on Feb 27, 2009
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Unlock setting on Cannon Speedlite 580EX II
Place flash on camera.
Go into camera's flash menu and change your setting there.
atdlee@yahoo.com
Apr 26, 2014 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Speedlite 580 pilot light on but flash wont fire
More info needed: Will the flash fire when you push the test button? Have you rest the camera you're using to factory defaults while the flash is mounted on the camera and turned on?
Jan 06, 2014 | Canon Speedlite 580EX II TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
I need a manual for my canon 580ex flashgun
580EX:
http://downloads.canon.com/cpr/software/camera/580EX.pdf
580EX II:
http://downloads.canon.com/cpr/software/camera/Speedlite-580EXII.pdf
Jun 30, 2011 | Canon SPEEDLITE 580EX TTL Flash
Af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
Jun 13, 2009 | Canon Speedlite 580EX II TTL Flash
Canon Rebel XT / EOS 350D Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
