Question about Frigidaire FWS833A Top Load Washer
Maytag Washing Machine Cycles Out of Sync with Dial
I have a Maytag A606 washing machine. The timer went bad, so I replaced it with a Maytag 205243 timer. Now the dial on the machine is out of sync with the timer - it is off about 30 degrees. I don't know what I could have changed or how I can adjust the relationship between the dial and the timer - it appears to be fixed!
  • owlmankillr Mar 23, 2009
    My old Maytag a606s washer (which I love, it's in mint condition and is built like a tank) seems to have "jumped time." I'm not sure what could have caused this, but here's the preface. I replaced the timer motor after it died with a 204663 Kingston-style motor (part number cross-referenced). The timer works fine, but the cycle is out of sync with the dial. After some experimenting, I found the correct start and stop points and marked them with small pieces of masking tape on the dial. I was just glad to get the washer up and running, but would love to know where the discrepancy lies. The dial is keyed into the shaft, which is keyed into the timer's main gear. The motor just powers the timer, and shouldn't have any bearing on anything but making it run and stop when actuated. Is it possible that my part cross-referenced incorrectly? Or could it be that someone had the timer body apart at some point and freed the gear from its keyway, rotated it 30°, and re-engaged? As a DIY guy and tinkerer, I'm baffled as to how this could have happened. Any insight would definitely be appreciated! thanks.
    Sergeant:
  • 311 Answers
Ive fixed lots off washers over the years[15,000 service calls] and was careful while taking parts off if i wasn't fulmilure with that model,but most timers and knobs have a key way so the knob can only go on one way.if thats not true for you, try this.turn the timer shaft till the washer is at the end of the wash cycle.[finished the load,it would be the final spin ,maybe five minutes long.when thats done the timer advances to off]now knowing that thats an off position set on your knob and then manuly turn it to the off position of the next cycle if it wont run you did it. if not you will have to go to the end of that cycle and remove knob and set to next notch in the knob,until you find the sweet spot.hope this helps God bless,tom
Posted on Feb 27, 2009
    President:
  • Frigidaire Master
  • 2,651 Answers
Maytag is imofamous for multiple parts for same product line. the par tnumber is determined throuhg a serial number break, as to which part is needed for what machine, soits quite possible that the timer you installed may just be the wrong one, forthe most parrt knobs and skirts only go on one way so i dont think you did anything wrong
Timer won't advance to next cycle
Make sure you are getting electric to the timer through all cycles. Depending on which cycle your washing machine stops at you may have a bad lid switch or if it won't drain, spin or agitate you may need to replace the motor/transmission belt or coupling.
Jan 16, 2010 | Maytag Washing Machines
Maytag top load washing machine model LAT9306AGE.. the timer doesn't spring back out when needed to during cycles
the timer on all maytag's ( top load turn clock wise/ push in to stop/ pull to start . the spring back ??? the timer shaft may be sticking and is hard to turn . remove face cap and clip pull dial and lube with a light oil or spray lube / reinstall and this moy help .. mm
Dec 02, 2009 | Washing Machines
Washing machine doesn`t change cycles. I can turn the dial manually and go from cycle to cycle with all working fine but if I don`t turn the dial it will stay on cycle for ever! This is an old machine and...
From storage, the timer probably has some corrosion on it, so perhaps you can just turn the dial several times around to clear the contacts inside the timer. There is a motor on the timer that may also be bad. If you can access the time in any way, i.e. opening the head, you can see if that motor is spinning. If you need to replace the timer, you may be better off getting another machine as it may not be easy to find it
Aug 26, 2009 | Fisher Washing Machines
Owner's manual for Maytag M300 washing machine
go to their web site should find it there if it's not to old of a machine
Jun 10, 2009 | Washing Machines
Machine not functioning
HI, this is a damaged timer device. the mechanism has failed and , it is unable to correctly initiate the proper washing cycle. simply replacing the timer/control will fix this issue..
Jun 03, 2009 | Maytag Dishwashers
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Machine will not automatically advance thru cycles
The timer has a motor used to advance it through the cycles. If the machine fills with water and the timer stays in one position no matter where you put it......even in the spin cycle, then replace your timer.
May 03, 2009 | Washing Machines
Frigidaire FWS833A Top Load Washer Logo
1,789 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
