Question about Power Probe 3 Combo Kit with Gold Test Lead Set
Power Probe III
.on display c 8 what do i do
  • Anonymous May 01, 2009
    c 8 is posted in screan
Dear Mark,
the screen shows "CB", not C8. Stands for Circuit Breaker. This means you have overloaded your Power Probe 3 and the internal thermal fuse has blown. You can simply reset it by pushing the button on the right hand side of the Power Probe.
Regards
Werner Klaassen
Coplan Europe
Posted on May 28, 2009
Engine light came on after car wouldn't start in the cold
It sounds like a fault in the display board inside your dash. Is the car running normally now? If so, wait till weather warms up and see if the 8 turns back to normal.
Jan 08, 2014 | 2008 Chrysler Town & Country
Mp730 says waste ink near full
To reset waste tank full error in MP730.
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press "Set" and the display shows:
Test Mode [1] - [8]
CF-FH3 :WLD-11-02
4b. Press "8" and the display changes to:
Test Mode [1] - [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 - 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button - for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Aug 03, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Acer aspires 4935g display change setting after installing internet exporer 8.
Its IE 8 which has a separate picture for background and the rest. Best option is to use IE 7 of Firefox which has no problems of this nature.................sodeep
Apr 24, 2009 | Computers & Internet
Center Console Display Not Working
Changed the battery yesturday in my Mazda rx-8. Now my radio/CD and my A/C won't work! It's all black! Wot to do???
Jan 28, 2009 | 2004 Mazda RX-8
The Waste Ink tank is full
go to www.neilslade.com/papers/inkjetstuffll..htl
scroll down to 370
CAREFULLY FOLLOW INSTUCTIONS
1st remove USB cable
take your time BETWEEN OPPS
print out ???????????????????????instruions FIRST
hit the red triangle followed by scan copy scan
you should now be in service mode
now slow down it is not fast
dj
PS your tank is a bin and could over-FLOW on to your nice sheep skin RUG=warning
Jan 26, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Error ##334 show up on display. what is it meant exectly ?
2. Press "Copy" Key
3. Press "#" Key
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
8: PRINTER TEST
[2]---[8]
8 – 3 : EEPROM Clear
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
Replace all the Ink Absorbers.
QA4-1012-000
QA4-1013-000
QA4-1014-000
QA4-1015-000
QA4-1055-000
Reset the counter to zero.
Replace the printhead. QY6-0042-000 (now QY6-0064-000)
Should cost you about $54 if in the US.
This will only work a few times. Eventually, it will fail to reset
and you will have to replace the Printhead. I hope this helps.
Nov 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
How do you set the clock nissa versa 08
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
Nov 11, 2008 | 2008 Nissan Versa
Power Probe 3 Combo Kit with Gold Test Lead Set Logo
3,325 people viewed this question
Top Power Probe Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Power Probe Measuring Tool and Sensor Expert? Answer questions, earn points and help others
