Question about Carrier Heating & Cooling
Carrier Infinity Control Programming Issue
Hello, Sorry to cantact yuo like this but I saw your name in a carrier string and was looking for some advice. I have a Carrier thermostat and heating system. (infinity Control SYSTXCCUID01-A, Furnace 58 MPV and 38TDB AC). The thermostat will not permit the opportunity to program the fan speed during heating mode. According to the homeowners guide (page 23), it indicates the programmable fan is automatically defaulted to off. Your dealer will need to turn programmable fan on in the delaer thermostat setup screen. Do you know how to accomplish this? Thank you. Mike Ramos
  • 38 Answers
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Posted on May 07, 2009
Carrier infinity 2-stage heat pump, Error 56 - Temp sense out of Range; and frost forming on heat pump coils although outside temp is 60F
That unit is a very complex machine. The temp sensor out of range issue may be as simple as the sensor being unplugged, or the sensor/outdoor control board needs to be replaced. The "range" it states it an ohm value in the sensor, that the board cannot evaluate properly.
Oct 18, 2017 | Carrier Heating & Cooling
Is it correct that Carrier had 5 year waranty back in 2007?
Try looking up your own warranty. Check carrier warranty on your model and serial number located on data plate on machine
Dec 10, 2016 | Carrier Heating & Cooling
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
N96 shows numbers instead of names
This is actually a carrier issue. It is in the programming of the number on the network. You may want to call your carrier.
Jul 06, 2009 | Nokia Cell Phones
The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
May 21, 2009 | Heating & Cooling
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Carrier Infinity from 1994 does not start
The Carrier Infinity has a control board that will flash out a pattern giving you a hint of what could be wrong. To find it, remove the cover off of the furnace and you will see a small round clear window. Look and count the blinks. Then compare that number to the diagnostic chart found on the back of the furnace access cover.
Let us know what the pattern is and we can help you more.
Oct 22, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
1,215 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
