Question about Microsoft Xbox 360 Console
Xbox restarting, DVD drive won't eject or read discs after
After a little while gaming, my xbox will restart without a error message or anything. after it restarts it will not eject discs, or read the disc that was already in. Cannot play again for another hour or two sometimes a whole day. When it comes back on the whole thing starts all over again. Would getting a replacement dvd drive fix the problem?
    Problem Solver:
  • 16 Answers
No, your motherboard and DVD drives have to match.
Posted on Mar 03, 2009
How do I fix my xbox game the xbox keeps saying unreadable disc clean with a soft cloth and restart the console.
If you get the error with just one game, but not others, unfortunately it is likely damage to the disc. If it is under warranty, or if you bought it at a return-friendly place, maybe you can get a replacement. If the system is giving you this error with several games, it is likely the disc reader in your Xbox. The Xbox 360 has a well-known issue with DVD drive failure over time. If your system is still under warranty, or sometimes even if not (because this was such a big problem for Xbox), Microsoft may repair it. Try calling them and patiently discussing it. If it is not under warranty, and you are good with repair work, try this: http://hardandsoftgaming.wordpress.com/2011/03/12/replacing-a-faulty-xbox-360-dvd-drive-firmware-flash-or-circuit-board-transplant/
Jul 25, 2014 | Video Game Consoles & Games
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Open tray error and thensome.
Unreadable disc errors or open tray errors are commonly fixed by pot calibration or laser assembly replacement. Pot calibration is the cheaper of the two, and if it fails and burns out the laser, well, replacing the laser would be the next step anyway.
You shouldn't calibrate the pot without an ohms reader simply because you can burn out the laser, but you CAN wing it. I'd advise doing some searching on DVD Drive pot calibration for the Xbox 360, simply because I don't know which drive you have so I can't help identify anything for you.
I will say you have to disassemble it down until you see the motherboard, take out the DVD drive, open it up, and then calibrate the pot with a very small screwdriver. The location of the pot depends on your drive. If this fails, then buy a new laser assembly and replace it in the drive.
p.s. pot calibration is fancy terminology. There are basically 2 "screws" inside the drive, 1 pot is the DVD/games, and the other is CD. You'll want to very slightly tweak the DVD/games pot until it works, testing with each tweak. You barely need to adjust this "screw" for a significant change to happen. Also, always test with a DVD and then a game. It will read a DVD before a game.
Apr 09, 2010 | Microsoft Xbox 360 Console
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
My xbox360 will not read disc, message reads
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
For disc-specific issues, check the disc for any visible signs of damage or dirt. Hold the disc by the edges without touching the top or bottom surfaces with your fingers. Clean the disc by using a soft cloth. Lightly wipe from the center outwards. Do not use solvents or chemicals to clean the disc.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked also if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Let me know of this helped and please do take time to rate my solution
Happy Gaming, Happy Holidays
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Premium System for Xbox 360
Xbox 360 disc drive is not reading discs, comes up with
time for a new reader only around 15 pound or 28 or so dollors on ebay and see you tube on how to replace drive its not to hard to do
Nov 20, 2009 | Microsoft Xbox 360 Console
Disc read error clean disc
The laser hasn't necessarily failed. This has happened to me in the past with certain games. I solved this problem by deleting the Xbox 360 cache. This can also solve various other problems on the console.
Clearing the cache removes all game updates which means you have to download them again but it WILL NOT remove your save games and your content so it's safe.
To clear the cache, do the following:
1. Go to the System Tab and select Storage Devices.
2. Highlight your HDD and press Y for options.
3. Enter the following button sequence: X, X, LB, RB, X, X.
4. When the system asks if you want to perform maintenance, choose yes.
5. Now restart your console.
If this doesn't work I'm not sure what to suggest, it probably is a hardware fault.
Hope this helps a little.
Nov 15, 2009 | Microsoft Xbox 360 Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
My xbox 360 keeps on restarting
hit the bution by the on bution and in dack of the controlor
Mar 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
624 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
