Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer is working good but the fresh food side is warm.
The fresh food side is warm and the freezer is working fine.the compressor is running good,there was some ice build up on the top vent inside the fridge,tryed to use a hair dryer and melted it ,but still no air comming out ,,the fridge is only 2 yrs old and there is no warantee left on it but the sealed components,,(compresser) its a kenmore elite side by side with water and ice machine in the door ..any sugestions would be great...thank,s
  • 1 more comment
  • lek1938 Feb 27, 2009
    Similar problem on Kenmore 363-60221000 frig-freezer unit. Refrigerator warm (temo control coldest) can't keep milk from spoiling, Freezer unit has ice & frost on back pannels from under icemaker down 3 feet. Unit can't freeze water or make ice. Cold enough as mini frig. motor runs constant coils clean good wind blow outside of unit.
    Also 4 - 5 years ago similar problem - think defrost unit was bad. Is this the same or could there be other issues,
    Please help with suggestion as I don't know about the expense of a repair man. I am retired
  • jefflynn5 Mar 10, 2009
    I have a similar problem. I have a kenmore model 569826 side by side. The fresh food side is warm, the milk keeps spoiling. No air is coming out of top. The compressor is running. Ice is built up around food and cabinet. Also 1 inch of ice is is frozen in bottom of freezer. Ice maker is working fine.
  • headache123 May 01, 2009
    Help please,
    Kenmore Model 106.50706*601 side by side
    Freezer works fine. Fridge is warm at 60 degrees. Ice build up at the (vegies control switch) at the very bottom shelf on the left side. Cleaned dust from bottom back of fridge. The control switch for Freezer side cannot go pass 3 on scale of (1-5). Switch springs back when attempt to raise to number 4. A few days before incident, heard rattling and gurgling sounds. Got fridge for a little over 2 years.
  • Kenmore Master
  • 4,655 Answers
I will need to get a little more information to help you better. Sounds like the defrost timer is bad but I will need a number like for example 915.125869
Let me know, Thanks Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Posted on Feb 27, 2009
The freezer is running and cold, the refrigerator seems to be getting warmer like as if the cold isn't transferring. Is there a fan suppose to be running or what?
It is quite common for a refrigerator to begin the first signs of a defrost problems once he fresh Food section begins to warm. Auto Dampers are an additional component to check while searching for the true reason for Fresh Food compartment warming. First look inside the freezer compartment and and see if there is a layer of frost building on the rear wall. If yes you will need to manually defrost unless you have anothr place to store the freezer goods. Unplug refrigerator and then remove the rear panel of freezer to get a good look at the snow covering your evaporator coils. Defrost with a hair drier. Now we need to look for the cause Auto Damper, Click here for the photo location of these parts=> MSD2756GEW Controls Section the adaptive defrost control is most likely the problem and is listed in the photo as location 13 and the auto damper
61005971 Damper Control Assembly
61005988 Adaptive Defrost Assembly
The Auto Damper model refrigerator has two controls and both have capillary sensing.
The Auto Damper controls the fresh food temperature and the Freezer Temperature
Control guides the freezer temperature. The fresh food compartment temperature is maintained by a damper assembly located at the back of the temperature control housing. Changes in air temperature cause the damper door to open and close. A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the coldest position increases the flow of freezer air into the fresh food section. The freezer compartment temperature control warms at a faster rate and cools at a slower rate, increasing the compressor run time necessary to maintain a satisfied freezer temperature control.
Click Here=> Here is how to test a Maytag MSD2756GEW Auto Damper
There is always other possiilities but I see two other things that may cause this and that is the defrost heater with defrost Thermostat=> 61006199 Defrost Heater Assembly
I know this was long and possibly confusing but please ask if you should have questions or one on one assistance, Thanks, Sea Breeze
Sep 14, 2011 | Maytag MSD2756G Side by Side Refrigerator
Freezer not working
the symptoms you describe, freezer temperature rising while the fresh food section "seemed" ok, my guess is by the time you read my response, the fresh food side will be just as warm as the freezer. when the cooling pattern is similar to this, it has to do with the compressor no longer running. the compressor itself may be ok, instead the starter has failed, but i would not recommend you even attempt this yourself, as you can cause permanent damage to your compressor, property damage to your home, or electrocution hazards to your self. I would highly recommend you have a reliable refrigerator repair service at least inspect it for you.
Apr 02, 2010 | Amana ARS2464B Side by Side Refrigerator
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
COLDEST position increases the flow of
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
My compressor runs but I think it shuts off and stays off too long...the box gets to warm and the ice starts to melt before it starts again
First of all, before you do anything, clean the coils under the refrigerator. I couldn't tell you how many refrigerators I've 'fixed' that needed nothing more than the coils cleaned. Dirty coils can cause a multitude of problems, many of them with the exact same symptoms that would be expected when refrigerant components fail. Dirt is the #1 enemy of any refrigeration unit.
If that doesn't help, since both sides of the refrigerator get warm before the compressor kicks back on, I'd suspect the fresh food temperature control thermostat. Not an easy fix for the average homeowner unless you've got specific skills in appliance repair.
Before you do anything, try this. Turn the fresh food thermostat all the way up, the set the freezer setting at a higher than normal setting. The way the system works is that the fresh food thermometer turns the compressor on and off and the freezer control simply controls how much of the cold air from the freezer is diverted to the fresh food compartment.
If you turn the fresh food thermostat higher, the compressor will run longer and adjusting the freezer control to a higher setting will allow less cold air into the fresh food compartment, forcing the compressor to run longer in order to cool it to the thermostat setting.
If the settings have to be abnormally high, this is a workaround, rather than a fix. To get a permanent fix, you'll probably have to replace the fresh food control thermostat.
I hope this was helpful to you or to anyone reading it.
Oct 10, 2009 | Amana Refrigerators
My side by side freezer is working fridge wont get cold,compressor is working.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Aug 29, 2009 | Frigidaire FRS26R4A Side by Side...
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fresh food side warm. Freezer works fine.
I think you are short of refrigerant, needs to be topped up and checked for leaks.
Mar 03, 2009 | Samsung RS2534 Side by Side Refrigerator
Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
Apr 24, 2007 | Frigidaire FRS23R4A Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
288 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
