Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Agitator not turning properly
My machine was making a noise similar to the one when the wash load is imbalanced. When I went to check, I discovered that the agitator wasn't turning properly, like it was stuck. I turned the dial to spin and it spun okay and I took the clothes out. I then noticed that I was able to turn the agitator manually which was not possible before. I'm thinking there's some kind of disconnect between the bottom part of the agitator and the top part. I don't know. Also, when I took the clothes out, there was some sort of grime/muck on them that I know they didn't have going in. Do washing machines ever need cleaning?? This one is 9+ years old.
    Novelist:
  • 172 Answers
If you are talking about the upper part of the agitator, this is a common problem with well used machines.
Little plastic dogs that grab the serrated sides of the agitator wear down the grabbers. Pull of the cap on top of the agitator and then the cup at the bottom of a well inside.. You will see a bolt head, remove it and the upper part of the agitator comes off.
The dogs are about $5 at Sears or other appliance parts store. It is tricky to replace them, so you need an appliance person to describe how to do it, and print you a copy of the parts break down of the agitator for reference, so an appliance store that sells parts is the better place to go. Sears won't help you with it.
If you are not all that handy, I would not recommend you do this. If you don't understand the technique, or able to intuitively figure mechanical things out for yourself, you could be pulling out you hair. If the person who explains how to replace these dogs doesn't mention doing it with the agitator up-side down, then they don't know how to do it either. Good luck, and you will get a great sense of accomplishment if you succeed. If you break one or both of two little plastic tabs that snap the lower part of the upper agitator to the lower part of the agitator, don't worry about it. They just keep things together and the dogs from falling out when you tip the agitator upright again. You can still hold it together with both hands in order to slip in back on the agitator spindle in the washer and bolt in back on without these convenience tabs.
Posted on Feb 27, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Excess noise coming from washer.
check to be sure it is agitating and spinning, if not you need to check the belt if equipped and the agitator. I had a similar problem and had to replace the agitator because it was stripped out. Very simple to do, remove the agitator cap and unbolt. Then reverse to install in what I have done. I have always been able to find part catalogs online that will show you all parts and how they fit together. Just search model and make.
Feb 04, 2014 | Kenmore 2942 400 3.2 cu. ft. Top Load...
How to disassemble drum from shaft of cw6000w model
my washer agitator will not move or make its usual half turns it makes loud noise i went out and bought a new bas for it tryed it no luck went to take spline off offdrum to fix gaskets or whatever just to check wont come off
Dec 09, 2012 | Crosley CW6000 Front Load Washer
Grinding washing machine agitator
more than likely the pump is the part that is making the noise. You can verify this by leaning the machine back where you can see the pulleys, your pump will be the one in the back. Remove the belt and each pulley should turn smoothly. The part number for the pump is 35-6780
May 28, 2012 | Maytag Washing Machines
Kenmore stopped agitating
broken motor coupling between the motor and tranny cost is about 15 bucks can get from repairclinic.com
Feb 27, 2010 | Kenmore 24032\24036 Top Load Washer
Whilrpool imerial series washer making strange noise
The agitaor coupling or drive mechanism is stripped. You will have to pull the agitator up out of the machine to find which of the parts need to be replace. Most likely th agitator coupling.
Jan 27, 2010 | Washing Machines
I have a model 110.81375130 Kenmore washer that is making a grinding noise during wash cycle. I already replaced the agitator shoes (similar to agitator dogs on other models). The bottom agitator is only...
A grinding noise from a washer more often than not means that your motor coupling is worn or broken. The coupling is a small plastic and rubber piece between the motor and the transmission. Not too difficult to replace yourself and very inexpensive. If it is the coupling you may see bits of rubber beneath the machine. If you look up underneath the machine it will be obvious of the coupling is your issue. If not I would recommend calling a licensed repairman to check it out.
Dec 12, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer making loud noise. Shuts off, not draining.
It appears that you have an imbalanced load, or a nearly balanced load with a machine that easily goes off balance during spin. I would suggest:
1. After the unit trips on imbalance and stops spinning, open the lid and redistribute the laundry load inside to balance its weight equally around the interior of the drum. Note that cotton fabrics hold much more water than synthetics, and this has resulted in imbalanced loads even though they visually appear to be balanced. Close lid to restart spin.
2. Remove the front panel and check both tensioning/centering springs on the sides of the tub. A loose spring could easily cause the machine to go off balance.
3. Finally, check the main bearng play by holding the drum steady and moving the top of the agitator spindle horizontally toward the rim of the tub. Any excessive play is a clear indicator that bearing is excessively worn and may be resulting in an unbalanced load.
Oct 05, 2009 | Maytag Washing Machines
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
