Question about Plumbing
Bathtub water does not get hot enough-
Does a Danze faucet have some sort of govenor to limit how hot the water can get for the bathtub? Our tub water doesn't get nearly as hot as water in our kitchen sink or other bathtubs in our home. Turning up the water heater does not affect the temperature. Water at other facets gets hotter, but not at the tub where this new faucet is.
  • Thomas F. Schneider May 11, 2010
    Many of the single lever(mixing faucets ) have a  mechanical setting under or behind the handle that limits the amount of hot water being mixed with the cold. maybe you does too?
  • Anonymous Mar 26, 2014
    Cabano faucet problems
  • 23 Answers
Take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Posted on May 12, 2009
The kitchen hot water down stairs gets very hot, but the upstairs bath tub does not put out enough hot water? What is the solution
Posted on Apr 17, 2010
My shower temperature keeps going up and down until after a few minutes of showering the cold id all the way off and hot is not that hot. I do see a lot of white chalky stuff inside the bath tub spout - it is hardened on the inside of spout. What should I do? Do I have to take down the tile on the wall to get to the plumbing inside the wall? Ugh - what a job! Pleae help before I do that - would like to take a nice long hot shower with out messing with the fausets continually. Thanks for your help.
Posted on Oct 11, 2009
Tub faucet (hot side) won't turn off when tight and the shutoff valve won't stop the water either
sound like you need a new valve in the hot water Faucet the rubber washer or cartridge depending on what type of faucet you have
May 09, 2014 | Sunrise Specialty Cast Iron Claw Foot Tub...
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
LADBS Plumbing inspector says we need a temperature regulator for an In-Wall Lavatory Kit in a tub. The tub does not have a shower nor a wand? Which section of the code indicates this?
2010 International Plumbing Code
414.5 Limitation of Hot Water in Bathtubs and Whirlpool Bathtubs.
418.0 Shower and Tub-Shower Combination Control Valves.
Feb 28, 2013 | Newport Brass 1500 SERIES IN WALL LAVATORY...
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Hot water problem in bathtube
Make sure your hot and cold water lines arent crossed up. depending on how its plumbed in it could take longer to get to the tub then it does to the sink,
Sep 13, 2009 | Plumbing
Plumbing Logo
2,838 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
