Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Can't remove screw on lamp cover panel PT-43LC14
Can't remove screw on lamp cover panel on PT-43LC14. We have literally HUNDREDS of screwdrivers in the house...why won't any of them remove this one screw? It's like a Phillips but with a shallow slot. Phillips just seem to strip it and flats won't work eitehr. Trying to save $ by installing lamp ourselves....HELP!
  • guyote1 Apr 15, 2009
    need step by step instructions on how to replace lamp
Using a phillips head screw driver, you need to grip the unit with your left hand and then push really hard against the screw head before starting to turn the screw. They are very tight from the factory. Once it breaks loose and starts to unscrew, the rest is easy.
Posted on Mar 16, 2009
Replace lamp pt 61lcz70
make this steps and fix it. God bless you
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
Jul 31, 2013 | Panasonic PT-61LCZ70 Television
Tip
Panasonic PT43LC14 Manual Download
Download Panasonic PT-43LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-43LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-43LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-43LC14 Television
Thermo fuse box noise, screen not on
have u replace the lamp on this unit , if not that would be ur problem the lamp is at front of ur tv just remove the speaker grill and u would see a small door , use a phillips screw driver
Apr 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Pt-43lc14
To reset the Lamp timer back to zero
simultaneously press the "down split channel" button on the bottom of the remote and the down volume on the TV for 5 seconds or more. You will get a message on the screen that the time has been reset to zero.
May 22, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Lamp replacement
Sure, I do by myself. Seat on the floor in front of the TV
!st. step: Grasp both side of the silver front cover with your
fingertips and pull it from projection display.
Then remove it.
2nd. At your left hand you can see a black knob. Turn the
open/lock knob to the left. Pull the black unit that have
the lamp inside. Cover out and down to open.
3rd. Loosen the lamp (black unit) screw with screwdriver.
Grasp the handle of the black unit lamp and slowly
remove the unit.
4th. Insert the new lamp black unit being careful. Tighten the
black unit lamp screw with a screwdriver.
5th. Close the lamp cover. Turn the lock/open knob to the
right.
6th. Replace the silver front cover. Finished.
R. Vega from Puero Rico
Apr 28, 2009 | Panasonic PT-52LCX65 44" HDTV
My picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Chage lamp on Pt-43lc14-K
On the front, under the screen there is a large plastic cover. The far right side of the cover has the black decals "HDTV 1080i" and "VIVA bb3 sound" on it. There aren't any screws holding it on, just pressure snaps. Pull the sides of it off gently and the three or so foot long panel will come loose. You'll see a black plastic panel now with two doors, one in the middle and one on the left of the middle door. The one on the left has a white lamp warning label decal and a black screw holding it in place. Remove the screw and take off the door. Inside is the lamp housing. Some models have a a screw on the right side of the black plastic housing, holding it in place. Take out that screw and pull the housing directly out toward you. You now have the lamp housing. If you are replacing it with a new lamp and housing just push the new on into place and reassemble, you're all done. If you are replacing just the lamp, you have a little more disasembling to do. But its not hard. If you need further help, post a comment and I'll send pictures. Good Luck.
Jan 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
LAMP REPLACEMENT
lamp replacement on this set is through the front of the unit... the bottom front panel is removed to acess the lamp door. Place your fingertips under the front cover and pull it from the display. there will be a lamp cover door with a screw to remove. then you will have to loosen the screws in the lamp and pull the lamp out
Feb 22, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
