Question about RCA HD52W59 HDTV Projection Television
Picture is blurry. when i look at tv it looks like im watching with 3d glasses on.
  • RCA Master
  • 8,617 Answers
You can get expert help with that problem at the following link they have the parts for less than 12.00 to repair that issue. Leave them a email with your model number and symptom
http://servicemanuals.vstore.ca/
Posted on Mar 04, 2009
I am getting a blurry picture that kinda makes it look like a 3d movie without the glasses on with alot of blue
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is the causes and already dead to have many of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures many problems.The tvs shops will cost u like $300-$350 for parts and labors.
Sep 07, 2011 | Panasonic Televison & Video
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
TV is blurry and the red and green look as if the picture is in 3d and I need glasses. Can I fix this myself?
There is almost nothing that can be fixed by yourself if your not trained in high voltages and advanced circuitry now days. This sounds like it could be your color guns going bad or the power supply.
This set also has an issue with The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.
Jan 12, 2011 | RCA HD56W58 56" HDTV
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
Tv looks blurry on the right side
You will also find there is colour disorientation in these areas. The reason is that your settings on the york had shifted, also it could be due to failure of the degaussing coil, or if there is any fault with the convergence inside the picture tube which could be a major fault.
Try to degauss, see the picture tube neck for any ring magnets out of alignment, also check the focussing in the rear panel which could have shifted.
Jun 08, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Tv picture is blurred
YOU MUST REPLACE YOUR CONVERGENCE IC S
COST 400 DOLLARS
Jun 03, 2010 | RCA P52926 52" Rear Projection Television
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Picture is blurry
remove front panel and check the 6 control knobs adjust the intensity of each color as well as the focus of the picture with those colors.be sure to mark the knobs so you can return them to there original position if the set shuts off. Good luck
Jan 28, 2009 | Hitachi 51F500 51" Rear Projection...
Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
Jul 20, 2008 | Philips 43PP9202 43" Rear Projection...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
