Question about Apple iPod nano MP3 Player
Water damage my ipod went through the was or somethig and it works fine but like i plug it into the computer and it works but when i take it out it goes black. Can it be fixed??????
  • 342 Answers
It sounds to me like you need a new battery for your iPod. To order a replacement battery kit, you can go to ( There is also a free video at ( Below is also a step by step instruction (guide) to taking apart the iPod piece by piece so that the replacement can be done in an easy safe manner. If for any reason you have difficulties please do let me know :)
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Posted on May 19, 2009
I dropped my in the toilet and it was working fine until about 20 minutes later the screen just went completly white. What do I do?
Hi Lizzy,
There is probably some water still in your ipod causing your problem.
Firstly, switch your ipod off. This can help prevent any more damage being caused.
Then, leave your ipod in a warm dry place, an airing cupboard or near a radiator (not on top!) for 6-8 hours.
After 6-8 hours try turning your ipod on to see if it is working again.
If it still isn't working turn your ipod off again.
Fill a small bowl with rice and submerge your ipod completely in it over night. It sounds a bit strange, but the rice draws out any of the remaining moisture in the ipod.
In the morning take the ipod out and get the rice out of anywhere it may have got stuck and try again.
Regards, sjstore2
Jan 19, 2011 | Apple iPod nano MP3 Player
Alright so my ipod touch was dropped in cedar water and was working fine after i let it dry then the next day it is not working at all it wont turn on and the computer doesnt recognize it anymore PLEASE...
it probably is one of 2 things. The battery shorted out or it actually caused water damage later on that night. Downside to apple products is you cant remove the battery when they get wet almost guaranteeing damage. Best thing to do is to send it to a repair center such as this one. They guarantee there work and can fix about any problem that could have arised, but even if you just got it and it may be under warranty apple doesnt cover water damage.
Jul 12, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Went to apple store recently & had tech restore my 8GB i-pod touch restore (completely froze up and I couldnt get it to restore?). Now when I plug it into my computer (my computer and I-tunes) doesnt...
Try to restore the general settings of the ipod by going to General Settings>Reset>Reset All Settings. On The iPod. If This Doesnt Work I Would Take It Back To The Apple Store And Consult One Of The Technicians
Nov 10, 2009 | Apple iPod touch
Ge 3cordless phones 5.8ghz can,t set time and day ,
went and got another one somethig was wrong with the phone ., the two work fine but the 3rd one doesn,t the other 2 are fine so that,s ok , i wonder if these are good phones , thankyou for helping me . sandy
Jul 09, 2009 | Uniden Cordless Phone
I dropped my ipod touch in the sink and it now it doesn't work
to fix this, you're going to need your ipod, a plastic zip-lock bag, and uncooked rice. first, open the bag and fill it halfway with uncooked rice. then put your ipod in the middle of it all. then zip the bag and let it sit for about a day. the rice should have absorbed all the water by then. most of the times, this will work. but sometimes, the ipod is damaged beyond repair by the water. good luck
hope this helps ;-)
Apr 04, 2009 | Apple iPod touch
Ipod touch
Not with water damage. It should be taken apart asap and get the moisture out of it.
They do make waterproof containers for IPods. Most are reasonably priced.
Jun 24, 2008 | Apple iPod nano 3rd Generation
My Ipod Nano went throught the wash?
Hello AllieBaba,
I am sorry to hear about your Ipod Nano. Unfortunately Best Buy's™ Product Replacement Plan (PRP) does not cover liquid or physical damage. As such, the PRP would not cover the damage sustained by a MP3 player that was run through the wash.
Best Regards,
"Go Ahead. Use Us."
May 31, 2008 | Apple iPod nano
Ipod was exposed to water
pluging the ipod into the computer while wet will damage the device further, take it a part and dry very carefully.
Apr 21, 2008 | Apple iPod nano
Apple iPod nano MP3 Player Logo
93 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
