Question about HP Officejet 6310 All-In-One InkJet Printer
Scans @ 75-80% of original do I get it to scan @ 100%
When I scan a piece of paper the finished scan is approx. 75/80% of the original paper...I need to know how to set so that it scans the paper the same size as what i am this possible ?
  • lernst Mar 01, 2009
    No, it prints out at 75-80% as well.....
  • gnelson83 May 11, 2010
    is it just viewing the image at 75-80% after you scan it? some programs default the size to smaller that 100% just for viewing purposes.
The page will appear to be 75-80% of the size if you scan it in to an application like Word or Open Office because they will add Margins to the page. The scan image will be forced into these margins. You can enlarge in the scan on screen, within the application, by dragging the corner nodes on the image. It is worth bearing in mind that the scanner will scan the margins on the original page so you can either select a smaller area to scan or crop the image to get closer to the original size. The Other ways to get the desired results is to scan the document in to a graphics package. The scan image is a graphic, not a document, so you will get the correct size when printing. Alternatively consider using OCR software to turn the Graphic into a document. This will turn the image into editable text.
Posted on May 08, 2009
    Problem Solver:
  • 15 Answers
The only thing I can think is the scan or print settings on the printer itself. there should be a way to adjust the size from either the printer or the preferences on you computer in the print screen.
Posted on Mar 01, 2009
I am getting a blue line on my scans when utilizing the feeder
The feeder sends the original across a small piece of glass. The scanner stays in one position as the paper runs across it rather than the scanner moving and paper staying still. The little piece of glass is probably a 1/2 inch by 12 inch glass. just clean that strip of glass. use alcohol. there is probably some whiteout on the glass. It will appear as a dot. When the paper runs across it, the dot is run across the whole page causing the line. if you cant find the strip of glass, run a scan and try to see where the scan light sits while it's running. Clean everywhere where the light sits.
Jan 15, 2011 | Office Equipment & Supplies
When using scan feature in my HP 7680 printer any document I scan never scans to its original size, it always shrinks by at least 30%; how can I scan documents to original size?
Try checking your setting. press scan menu (over by the fax buttons) then choose paper size. you may have it on a smaller size. i have mine on automatic. See if that works.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Scanning Different Sized Sheets
There should be a preview option that scans more quickly than actually scanning the page. Then after the preview shows, you can select the area that you want to actually scan and then you hit the Scan button. If you are using the Canon software, this should work for ya.
Nov 07, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
HP Officejet 6310 All-In-One InkJet Printer Logo
111 people viewed this question
Ben Johnson
