Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL10U2 gets hung up on spin mode
When it gets to the point where there are just 3 lights left (entering spin cycle), it hangs up. I can hear the motor operating slowly. I can always power it down, wait a minute, then turn it back on in another setting and advance back to that point in the wash cycle to continue. What gives?
  • billgodfrey7 Mar 01, 2009
    Why would it be a clogged drain or water pump if it will go past that cycle on all of the other settings other than normal?
  • 4berks Mar 05, 2009
    My Fisher Paykel GWL11 will not spin. I can hear the motor quietly humming, but no spin. The water will not pump out.
  • 172 Answers
The drain, water pump, or both are clogged with clothing lent or sponge from back of throw rug,etc.
It is easily underneath machine when you lay it down on it's face. Bail out as much water as you can before tipping, the rest will run out on whatever you lay it down on.
Pump comes off with a twist, and connecting hoses come off with spring clips. Clean out all hoses even if they don't appear clogged, with a coat hanger. Clean out water pump by removing face. It has screws or twists off, I can't remember.
See my other answer to this problem in another post.
Posted on Feb 27, 2009
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
Jul 10, 2013 - Uploaded by
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
My fisher & paykel intuitive doesn't spin it drains but that's it it also was getting stuck on cycles before braking down and not spinning could it be moisture do I have to change the circuit board?
Your washer is trying to tell you something is wrong. When the cycle interrupts and the machine starts to beep, it is in "fault mode" and it is correctly trying to tell you what is wrong with it. On models that have no LCD display, (GWL10, GWL11, etc) the LED lamps that normally indicate the various stages of wash cycles become "fault code indicators". On models with a LCD display, such an IWL12 for example, the LCD display will show the fault with a description. On all Fisher Paykel washers, you will find a detailed "tech sheet" located underneath the touch module of the machine, on the left side, in a plastic bag next to the water inlet valves/mixing chamber area. This sheet contains detailed info on fault codes and diagnostics. We always ask that people first read over this sheet and become familiar with these codes and what they mean. In many instances this will get you pointed in the right direction. To gain access you must UNPLUG the washer, and remove the two phillips screws that secure the control panel frame to the washer top deck. It also helps to remove the lid for ease of removal of the control panel from the deck.(simply open the lid 3/4 of the way up and lift it right off the hinges) Be careful not to damage or tug on the wiring connector from the motor control to the touch module.
NEVER attempt to enter diagnostic mode without first re-attaching the control panel to the washer.
Apr 23, 2015 | Fisher Washing Machines
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel washer spinning problem
The clutch? Take out center of washer (only small bolt/screw ) , take out agitator, and lube up the hardware , check for broken parts, or overly worn out metal pieces. Run a normal cycle.
If still persists, take off front panel to washer for an engine inspection.
Dec 18, 2017 | Fisher Paykel EcoSmart GWL15
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Jul 27, 2010 | Fisher and Paykel Washing Machines
Machine stops and will not move to next cycle--spin
Sounds like it it not recognizing that the lid is closed, could be a bad lid switch.
Apr 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
Dec 06, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel GWL11 Top Load Washer Logo
553 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
