Question about Cameras
Tape is stuck in Sony DCR-TRV 460 I have exterior disasemble mostly Can not see trigger to release to get out tape AL
    Brigadier General:
  • 8,619 Answers
Hi
Please look at a reset button/tape removal button on the left/right side of the unit.If you are unable to find them then open the side and back screws of the unit to eject it manually.
Posted on Feb 27, 2009
  • Rylee Smith
    Rylee Smith Feb 27, 2009
    Kindly refer to this link for detailed information on how to remove the tape for Sony DCR-TRV 460.
    Tape Mechanism
    Please revert for any clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Please see this link for resetting the unit---
    Sony DCR Reset
    Most of the time when a cassette won't eject from a camcorder it is because the video tape has gotten wrapped around the head drum, drive roller or some other mechanical part.
    Ther will be a roller on the righthand side toward the lens it is a wide roller with black rubber on it. Inside this roller you will find a small white plastic tube that inserts to hold the roller steady. Check if it is cracked. A quick tweak would be to take a tube from a compressed air can and cut it to the correct size and replace the broken plastic one.
    Also feel the gears check for the left one, it would be stuck and would not move. After pushing it and turning it with a small amount of force it will loosen up.
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
Jul 21, 2009 | Sony Handycam DCR-TRV460E Digital...
DVR TRV-27 is showing error C:32:11
The problem is a rubber tape tension roller. Simply eject the tape, look inside where the tape goes. You will see a black rubber cylinder that may have a white plastic tube protruding. If you have long tweezer or a hemostat remove the plastic tube which hold the rubber tensioner in place, then remove the rubber tension cylinder. Clean the shaft of the black rubber tensioner with alcohol on a q-tip. Replace rubber tension cylinder and plastic tube.
Also, the tapes can cause the problem. This process is possible by one person, but you may need another person or have three hands. The C:31:23 is tape tension error. The tape has become stuck. Simply eject the tape. Holding the tape upside down, pull back on the tape cover release slide on the left side of the tape, now take the hemostat and push the tape release tab, located opposite of the tape cover, push this tab down and back toward the back edge of the tape. Now while holding both those release levers, take a pencil and wind the tape past the bad spot or until the tape winds freely.
I did both of these and was able to use the camera again and view all my tapes!
Good luck and QUIT SPANKING YOUR CAMERAS!!!!
May 01, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
USB streaming function
how do I turn my camera on usb streaming mode
Jan 27, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony DCR-TRV 250
YES HE IS RIGHT, SONY $145 SEND IT IN, RIBBON FEED ERROR WAS MY C 31:22
Nov 25, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony trv 460 camcorder and HC- 40 mini dv humming noise
The noise is probably the motor running. As long as it doesn't appear on the footage, it's nothing to concern yourself about.
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Sep 14, 2005 | Sony Handycam DCR-TRV460 Digital Camcorder
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
