Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana side by side refrigerator is making a buzzing sound
Hey there, I have an Amana side by side refrigerator-- model drs2660BW. It has just started making a buzzing sound in the last month-- it buzzes for a few seconds, then clicks off. This happens every 5 minutes or so. The water connection for the ice maker is not hooked up, and we have lifted the ice maker arm so it does not engage. Any idea what the problem might be?
Thanks, Lisa
  • subaruru Feb 27, 2009
    It still cools great, both freezer and fridge.  Just an intermittent buzz, then clicks off.
  • Ken Bledsoe May 11, 2010
    Does it cool at all? Or just buzzes and clicks off.
SOURCE: Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
Posted on Sep 20, 2008
could be a relay failing, a long 2 -3 seconds hard electrical hum could be the compressor failing & the relay overload is doing it's job shutting down your overheating compressor, unplug it for 30 min plug it back in a slight hum & click off is most likely just a relay but a long hard electrical hum is bad news Compressor & if it has no warranty left on the compressor repair could run $500.00- $700.00.
Posted on Dec 21, 2008
philbran
  • 242 Answers
SOURCE: Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Posted on Jan 07, 2009
aborcass
  • 2651 Answers
SOURCE: A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Posted on Feb 19, 2009
  • 6 Answers
SOURCE: The ice is melting in my Amana arb2205.It clicks,buzzes for a few
sounds like a bad compressor relay. The compressor it self might be bad but 80% chance it is just the relay.
Posted on Oct 24, 2009
How to test Damper control in Amana DRS2660bw MFG No PDRS2660bwo S/N 10650033CT
the control damper does not control the freezer temperature call a repair man as it possibly needs freon added
Jan 22, 2017 | Amana Refrigerators
Model drs2660bw refrigerator- does the water supply come into the main water valve at the back or into one of the selenoid
The water comes into the valve on the back and then to the ice maker and the water dispenser, if it has one.
Nov 27, 2012 | Amana ATB1935HR Top Freezer Refrigerator
Amana drs2660bw refrigerator won't make ice any more
if freexer is not cold enough . this causing low or no ice prod . so ck the fan under neath and clean the coils in back . if this does not correct problem . you may have a bad ice maker .. mm
Apr 18, 2010 | Amana DRS2660B Side by Side Refrigerator
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
I have an Amana SxS (model DRS2663B) that is about 8 years old. About a week ago, it started making a sound - kind of a buzz coming from the compressor area (or the little box I identified as a...
You may have a bad relay/overload part number 12555902 runs about $15 but if the compressor is going bad it may not work.If you take the relay/overload off  turn it into your hand and shake it if you it sprinkles out like a pepper shaker go with the OEM part afore mentioned,but if it sounds solid and nothing comes out go with a hard start(SUPCO RC0410 also about $15) it will buy you at least another couple years in which to shop around for a replacement or save the money for a new compressor.You can call Amana to check on the warranty but most only had five years on sealed system.
Sep 27, 2009 | Amana DRS2663B Side by Side Refrigerator
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
83 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
