I get LInear PCM flashing on the screen
SOURCE: Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
SOURCE: STR-DE475 receiver flashes "PROTECT" when turned on
Protection is usually a sign of overheating or something is wrong at the power amplifier's output.
Theory: Protection is a delay and sometimes an internal test to allow the electronics to stabilize during power up before they are allowed to interact with the speakers. The most common cause of it remaining ON is that a speaker cable pair is shorted. Some isolation is required...
1. Turn the Power OFF.
2. Disconnect each set of the speaker wires that are directly attached to the receiver. Mark them so you remember where each one went. pay special attention to which conductor is on "+" or "POS" and which is on "-", "COM" or "Ground". You may elect to disconnect them one pair at a time if your sytem is complex and you don't want to lose track of where things were.
Turn the Power ON. Is the "Protect" indication gone from the display?
If YES, you have a shorted speaker wire or speaker. To isolate the specific cause:
2. Attach ONE speaker wire pair at a time and test it by turning the Receiver ON. When the "Protect" light returns you have isolated at least one of the cause(s). Disconnect the defective speaker cable and continue isolation of all speaker cables. Visually examine the cable at both ends for frayed wires that could touch each other or contact metal on the receiver or other objects.
To isolate further within the cable/speaker pair - disconnect the speaker end of the cable on the failing path. Try another cable that you know works, or at least one that doesn't cause Protection to stay on.
If you're electrically savvy and have a Digital Volt/Ohm Meter you can troubleshoot the short(s) with it.
If NO, there is probably an internal problem.
Is it solid or does it come on after the Receiver has been ON awhile.
It could be overheating.
Is the unit hot to the touch?
Is there a cooling device (fan)?
Is it stopped or clogged with dust?
Is there adequate ventilation around the unit for air to flow?
Clean any ventilation slots on the top and bottom of the unit.
Avoid stacking components that produce heat under an amplifier or receiver. Their heat rises. Also keep them away from other heat sources like like home heating vents and radiators.
Problem solid and NOT related to the speakers or heat: internal malfunction.
Let me know.
SOURCE: Sony str-de675 receiver has no sound at speakers when turned on.
This unit is having a problem with the preamplifier and power amplifier section. The reason to suspect this is that you can still hear sound, this is not likely if you ahd a failure in the power supply section. The unit may have had a failure in the amplifier areas of these sections, These are the signal amplifier sections that increase the power of the signal to drive the sound in the speakers .The Unit is probably in the protection mode reducing all power to prevent further damage to the rest of the receiver. You can go to the www.sony.com website support section and look in the frequently asked question and troubleshooting sections for problems like yours and see if they have any answers. On this website you can also find customer support. Ask them questions about the problem and see if they have any solutions.If all this fails to answer you problem, you can try opening the unit and looking for the problem yourself. Only work on the unit with it unpluged from the power source. Take off the top cover and look for any damaged areas, on the pc boards.They would be brown areas from excessive heat due to component overheating and possible failure.Look for capacitors that may have gone bad, they will be bulging from the top and bottom and may be leaking material from inside of them. Any component like this needs to be replaced. You may find burnt resistors and other failed components that will require a digital voltmeter to test.If you have expperience with this type of repair you might be able to isolate the problem and replace the parts. This may require the help of service information due to the complexity of the receiver's operations. Try to get a schematic or service manual from the web or a repair shop. This will have all the parts and a diagram of the all the different sections of the receiver. Usuall there is a power supply section, a tuner section, a preamplifier section, and a amplifier section. There also could be a equalizer section and other sections according the functions of the receiver. The failure most likely has occured in the preamplifier section or amplifier section. The problem in the preamplifier section could be a signal diode failure or a signal amplifier failure. in the amplifier section the problem could be in the output power devices which may be transistors or ic's depending on the type of output amplifier use in the unit. Usually not that hard to find with good service information and test eauipment.You may want to take this to a school that teaches electronic servicing and see if they will work on the unit for you for the cost of parts and a small labor fee. Call them first and see if they can help you out. I hope this helps you with your problem.
SOURCE: sound cuts out- cable tv
I had the same problem when I installed the new HD Comcast cable box (DCH3200), initially with my CRT through RF, then with my HDTV through HDMI. Problem solved when I replaced the box with the Comcast RNG110 I got from my local Comcast. It is a neat miniaturized box and it works extremely well on HD. There is no power switch on the box so before activation do not forget to put it on with the remote (cable, power, the green light will come on).
