Power button and brew buttons nothing works. Infuser is also locked in place. I have unplugged and plugged back in it goes through cycle but still buttons do not respond.
SOURCE: tried to remove infuser, must
Here is the complete user manual with pictures on how to remove the infuser.
If you have more queries ask us.
If you are satisfied with solution, do not forget to rate best solution.
Many thanks
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
SOURCE: insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
SOURCE: how to replace Delonghi magnifica
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
