Question about Digital Audio RT-7000 System
Remote does not work - Digital Audio RT-7000 System
  • 121 Answers
Batteries in the remote are always the first thing to check. The second is always that there is a line of sight to the front of the device that you are trying to control.
Posted on Feb 27, 2009
Samsung ht-c453 remote stopped working
kindly check the battery of your remote control...
Mar 08, 2013 | Samsung HW-E551 Home Theater Speaker...
Remote Control
What exactly the problem is with what remote.You said Remotes for TV and Video work perfectly now what remote is you talking about?
Oct 02, 2008 | Sony SA-VA100 System
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
Can't find remote for Bose Cinemate...is there any other way to turn it on without remote?
No, you need some sort of remote. Luckily this Bose uses IR for the remote and not RF. This means you might find a cheap universal remote that has a code for this. PC programmable remotes such as Logitech's Harmony, URC, and RTI remotes would definitely work.
If this was helpful, please rate!
Apr 07, 2011 | Bose Cinemate Digital Home Theater System...
Polk Audio DSW Pro 500 remote doesn't"t work. I've tried replacing the battery and was told by another technician to take the sub-woofer out and make sure the cable is plugged up to the amp and the IR...
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Mar 06, 2011 | Polk Audio DSW PRO 500 Subwoofer Speaker
My remote just stopped working on my technosinic home theatre. any way to reset the system?
Check if it is a remote problem or not:
-Using a digital camera you should see white vibrating light comming from the remote if it is OK.
- If nothing happens, remote problem.
1st: Change batteries.
2nd: Try to find a similar or universal remote for test. If your system is OK with this remote, your remote faulty. Take apart, probably some hit/drop broke the PCB inside.
- If you see white light through your camera, your device has some problem.
1st Check if your device is working (can operate with buttons/knobs in the device itself)
2nd Try in darker day period (no direct sunlight) and go close to the reciver.
Aug 28, 2009 | Audio Players & Recorders
Remote
Fine audio equipment from Japanese manufacturer's like Onkyo is typically "stand-alone", meaning there often is no universal remote control available that will work a given unit; those that will work are rarely capable of accessing all the features & functions such units employ...best bet is an original equipment remote control; recommend you try going to this site:
http://www.onkyousa.com/
and search for links to the P-3160 preamp & how to contact the Sales Department about cost & availability...
Jan 12, 2009 | Onkyo LS-V955 System
Remote not working,
Changed batteries on remote now they will not not work Help !
Jul 02, 2008 | Aspire Digital AD-225PSC Subwoofer
Remote Control Unit
Get a digital camera or mobile phone with the camera and the remote,watch trough the camera the remote( aim the remote to the camera like its the sub) and start pushing buttons on the remote.If the remote is OK you'll see flashing light of its IR led on your camera display.If there is no light the remote is broken
Mar 08, 2008 | Durabrand HT-3915 System
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
Digital Audio RT-7000 System Logo
24 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
jpmax14
Terry Hair
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
