Question about Brother Sewing Machines
Automatic needle threader off on Brother PR-600 II
I messed up the automatic needle threader and the hook is no longer going through the eye of the needle. I've tried bending the middle hook to the right, but the entire 'system' seems to need to go to the right more. I can't find where I would need to screw/unscrew anything to help move it...any suggestions?
bargainbox
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
RickE1
  • 202 Answers
SOURCE: Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Posted on Dec 01, 2008
mohammed387
  • 1952 Answers
SOURCE: Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Posted on Feb 12, 2009
  • 323 Answers
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Posted on Apr 11, 2009
  • 11 Answers
SOURCE: needle threader is not working bernina 220 activa
Use a magnifying glass to see if the little hook in the needle threader is bent so that it is not going through the eye of the needle. You might be able to gently bend it back with tweezers.
Make sure that your needle is in the upper most position when you try and the presser foot is down.
Posted on Mar 17, 2010
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
I have a really hard time getting the needle to thread.l I cannot manually pass the thread through the needle eye: the eye is just too tiny; and I cannot even see the hook part of the automatic threader...
I have that machine, and am wondering if your needle has a burr on it, try a new needle, #11 or #80. You may also have no hook in your automatic threader to go throught needle eye. My first automatic threader was defective, no wire to go through the needle to catch the thread. Take a magnifying glass and look when you change your needle and watch when you pull your threader down, do you see a really fine wire come through the needle eye? If, not yours is defective because it has to pull the thread into a little loop for you to pull your thread through it after you release the lever quickly, Mine was a Singer and they sent me a new one right away, Brother will do the same for you, I am sure. Another thing you can do is go to your dealer and have them inspect it, I went to JoAnn fabrics and that is how I learned that I was not crazy, it was the machine,
Apr 20, 2011 | Brother CS-6000
The hook which enters the needle is bent and broken
I assume you're talking about the hook on the automatic threader, because that's the only bit that actually ENTERS the needle. If the hook gets misaligned just a bit or the needle isn't put in properly or becomes bent, it is unfortunately very easy to break the automatic threader head ... best solution is simply to get a replacement threader head ... they're not expensive and really should be regarded as 'wear and tear' parts that should be replaced every so-often anyway. If a new one fails to go easily through the eye of the needle, you may have to have the mechanism adjusted so that it rotates at the right height, otherwise you'll end-up breaking the hook again. Dont force it !
If you're referring to the hook/shuttle, then you have to replace the hook/shuttle if it's been seriously damaged - minor scratches can be polished-out with 1200 grit or above, but, again, it's better to replace this part than try and repair because unless you know what you're doing, you can mess-up the profile so that it wont pick up the loop when the needle is rising through the material and you'll get bad stitch formation.
Feb 08, 2011 | Bernina Virtuosa 160
The automatic threader does not work
Please refer to page 33 of the user's manual.
The needle has to be in the highest position for the needle threader to align with the eye of the needle.
Threaders will not work if the eye of the needle is too small for the wire on the threader.
Sometimes the wire gets bent if it was forced against a needle that was too small or if the needle was not in the correct position for the threader to work.
The wire can be bent back into place, but you have to be careful as it is very thin and can break.
If the wire is broken, the dealer can order a new threader - they are not very expensive and are easy to install.
Feb 19, 2010 | Brother XR-65t Mechanical Sewing Machine
How do you align the needle threader on Husqvarna Quilt Designer II?
You need a torx #6 screw driver to loosen the screws on the back of the threader, (I use magnifying goggles to see the threader) then put the threader in the down postion and look to see and make sure the hook of the threader goes through the eye of the needle. Holding the threader in the down positon with the hook sticking through the eye of the needle, tighten the screws on the backside of the threader, Double check it (slowly) to be sure it didn't move while you tightened the screws.
Nov 06, 2009 | Husqvarna Viking 1
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
I can't thread the Shark Euro0pro 384 unng the automatic threader
You need to check to see that there is a small hook going through the eye of the needle when you use the threader. A flashlight or bright light will help. So will a magnifying glass. If it isn't, then no amount of trying will help.
If it goes through the eye, you need to see that your thread hooks into it so that the thread can be pulled through.
sewman7
Jun 08, 2008 | Euro-Pro Shark 60 - 384
Threading the needle of the embroidery machine
You may need a magnifying glass to see the tiny hook that should pass through the needle eye to catch the thread....
....if it is not aligned properly and does not go through the eye you will need to realign it....
...there may be a small screw attaching the mechanism, loosen slightly with jewelers screwdriver so you can move it but there is still some friction and gently engage the needle threader to see how far you need to move it, then gently, using a fine screwdriver, tweesers etc, nudge the tiny hook a little, check result and continue to adjust until remedied....re-tighten screw.
If there is no screw adjustment, a gentle bending will resolve the problem............but if there is no tiny hook, it will need replacing.
They are not easily broken, but only use gentle pressure to be sure.
May 22, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
900 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
