Question about Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35
Wiring diagram for a minn kota mk220 2 bank charger
I don't know if i have my battery charger is hooked up right>
  • Johnson Master
  • 3,498 Answers
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Posted on Jun 06, 2017
4 Suggested Answers
  • 91 Answers
SOURCE: minn-kota wiring battery charger 4 bank trolling
call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
Posted on Jun 02, 2010
  • 157 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Hello raventrans. I suggest you contact www.minnkotoamotors.com/index.asp and ask for est#406, Dave.
Posted on Oct 19, 2008
  • 25 Answers
SOURCE: how to wire up 24v minn kota to batterys
if you are trying to wire the batteries for teh 24 volt motor then you need to connect the positive of one battery to the negative of the other battery. then connect the trolling motor to the remaining two terminal of the batteries.
if you are trying to connect the charger to the batteries then each battery should have its own set of wire coming from the charger.these wires should be connected to the batteries in a set not crossed between batteries.
Posted on Feb 24, 2011
Minnkota endura c-50 shear pin size
You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
Trolling Motor Replacement Props Minn Kota Motors
You will find prop nut kits here just follow the link.
Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
When you series batteries to get 36 volts you have two batteries that are connected positive to negative, I have a four bank charger for my batteries and I am concerned that the two batteries that are...
no problem put neg on neg pos on pos on each battery but make sure you have charger on the battery it goes too look on your charger see if the banks are numbered 1 2 3 4 put 1 on # 1 and so forth # 4 goes on your cranking battery if you get a red light on charger then you have wrong wire on wrong battery and yes it will make you pull your hair out till you get it right . . .lol
Nov 14, 2012 | Minn Kota Boating
Minn-kota wiring battery charger 4 bank trolling motor e-drive
Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Battery charger
I have seen the threaded terminals on batteries where the threads do not go all the way down the terminals far enough to actually provide enough threads to tighten down wires!...whew..
Make sure the charger wires terminals are actually crimped on the wire and not the insulation..seen that too.
Jul 03, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Boat battery charging issue
Hook up a differant bank and see if it says charged, check volts of battery must read 12.6 volts to be fully charged. If it dont bad battery
Jim OMC Retired Mech
Jul 01, 2009 | Boating
Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35 Logo
1,954 people viewed this question
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
