Question about Goodman Heating & Cooling
Furnace kicking on once per hr unless thermo turned off,then on
My furnace will only kick on about once an hour unless i turn the thermostat off and back on. also the water will not flow out unless i crimp the run-off hose thing. it will keep running if i take the door off the electronic air cleaner and let it have more air flow to it. also, i do not get near the force of air from my vents as i did last year. i havent had much luck on a real diagnosis. i was told i need bigger vents, but the way i see it is they havent changed since the furnace was installed in 1998, so that cant be the issue now. oh, the furnace is a Janitrol by Goodman. Any feedback would be appreciated.
  • 3 more comments
  • debmc03 Feb 27, 2009
    I have the EAC plates out as well as the metal mesh filter and only using a thin regular filter. Even with the EAC door off for more air flow into the furnace, I do not get any more force from the registers. Also, when the furnace is kicking off, the "flashing codes" are 4 and I think after a little swoosh noise it flashed 3 times just a couple times. Also, being female I must ask a dumb question.......is there any vent door things inside the ductwork that comes open to allow air to the ductwork?? Just wondered in case something like that could be stuck partly closed??
  • debmc03 Feb 28, 2009
    I had a few vents closed, and lately another one or two partly closed in hopes of getting more heat to areas that needed it more, but I have since opened those in hopes of better airflow. So would the dirty A-Coil cause the low air flow???
    Would this also be a symptom or a cause of the water gurgling in the moisture hoses? The water just runs down the hose when I bend it upwards which I guess helps the vacuum inside and releases the water.
    Thanks so much for all the advice!!!!
    It is the water drain, however it is just a piece of flexable hose(poor rigged job when put in).Its the one that is in conjunction with the pipe that runs steam out the roof. It is about the same height as the motor. Unless I lift the hose to let the pressure off(or on,whichever) you can hear the water gurgling inside the furnace.
    Not sure about the length of running time now that all the vents are open.
    Just got another opinion from a house call (person with good reputation)that makes sense. The water hasnt drained off properly and over time that has caused water and acid to collect inside, which probably has caused the heat exchanger to get corroded and worse over time, which I guess has issues in the older Janitrol brands. There is a no cost program to get a new heat exchanger from the company. I can do that and pay to replace or get several $$$ off the cost of a new unit with minimal or no installation fee,and then I would have the warranty on the whole unit instead of putting a new exchanger in a 10 yr old furnace. I did mention the A-coil to the guy when he was here. He refered to a coil when elimanating things that could be wrong, but he didnt call it an A-coil.
    The $1100 is about what I will end up paying I think. You mention the A-coil, but wont that be new on a new furnace?? If I get a much better deal on the exchange program I will go with Janitrol,which is now an Amana product, and supposedly better than before??? But otherwise I will keep in mind the brand you suggested. So I should expect to pay $1100 or so just for the furnace, or is that labor also??
    I really appreciate your imput.
    I am in Southern Ohio.
    I do not have air conditioning with my current unit. Will use old window unit til it gives out,then get central. I will have what I need installed at the base of the furnace now so will be prepared for the addition when the time comes.
    I do not know the effeciency of the new furnace. The size,etc, hasnt been determined yet. Waiting to see about the exchange program, etc, before crunching numbers . The old one is 80 btus or whatever, and I have been told that is much more than my small house needs. I have about 1000 sq ft. and part of that is an unheated garage.
    Thanks so much for your insight, and your professional knowledge. It is hard to know if youre making the right decision sometimes. A gal on her own also has to watch to not be taken advantage of, although I am all into doing my own digging into the subject. I usually try to fix things myself ,except when it involves gas or electric I leave it to the pros.
    Thanks and have a great rest of the weekend.
  • 306 Answers
Your unit is starving for air. Either you have a dirty pre filter before the EAC (Electronic Air Cleaner) or the EAC needs to be cleaned. Or the A Coil is clogged up which needs cleaning. Have you ever cleaned the small pre filters ahead of the EAC? How about the EAC have you taken the EAC out and washed the plates off? I am just suggesting some feedback here so bear with me. ken
Posted on Feb 27, 2009
  • 2 more comments
  • Ken Bledsoe Feb 28, 2009
    There is no such thing as a dumb question debmc03. there is not door things inside the ductwork that allows air to come in. But read below. You are very close in your thinking. about doors.
    Now there are baffles that do turn to shut down the air flow inside the duct work. I wouldn't think they would be shut cause you would have to turn them. You can tell if you have these baffles by looking at the duct work as it comes out of the top of the furnace and looking for a lever sticking out of the duct work. Most of the time we install those baffles close to the furnace as to keep all the air close to send it to another part of the house.
    Are all the returns in the house open and no furniture on top of them right? And nobody would put anything down inside them. I am really leaning towards a dirty A Coil and they are a pain to clean for someone that hasn't done it before.
    The 4 flashes means limit switch has opened meaning to much heat build up. hence your low pressure on the registers coming out.
    And you had a service man come out and he suggested bigger vents? he should have mentioned the A-Coil being dirty.
    Dirty A Coil is just like a clogged air filter will not allow air to pass. I am not understanding the water issue you mention. On your furnace if you have a water drain line should be pvc line to a floor drain. Where is the hose coming from when you mention water hose. When you look at the unit tell me from the upper portion or in the middle or towards the bottom. You might have a 90+ efficiency furnace and then I would understand what you are referring to. Also tell me if it comes out of the unit as a pvc pipe.
    When you close off vents to your house that backs up the supply of hot air and will cause the unit to shut down too early in the cycle. Now that you have opened the other vents does it seem to run longer then it did? But the dirty a-coil will still cause a problem on air flow.
    Thanks for getting back so fast deb. Sounds like the deal with getting a new unit is the way to go. If at all possible try to get something other then Janitrol brand. Now just between you and me who you don't know from Adam, they are a very cheap brand. Ask about Temp Star brand they are what I install and I have put in at least 100 and not one problem over the years. I keep up on most of the units as I really try to keep good customer repoor. And at the same time they replace the unit get the A-Coil cleaned. The cost of a furnace is about 900 bucks maybe 1100 on a 90+ unit now keep this to your self some people charge about double that to make more money and then charge minimal labor to make it seem like the person is getting a good deal... ken
    The A Coil is part of the air conditioning system and would be extra. The heat exchanger has a warranty on most units of 20 years. I would think 1100 is the total of the difference between furnace and labor combined. Seems a little high I know when I put in a furnace only comes to only 750. Give or take. Can you tell me what efficiency the new furnace will be? They are rated at 80% 88% 90% 94% 95% And also how many BTU's is it going to be.
    A new heat exchanger would be around 200 but they don't make that type of heat exchanger any more so you get a new furnace. They are just charging you for the difference. Where do you live I am in Kansas. Glad I could help you even though you are getting a new furnace at least your A-Coil will be inspected and cleaned properly.
Gas furnace doesnt turn on right away after going below temperature setting. set at 70 and houes temp went down to 67 for an hour until furnace kicked back on. just replaced old thermostat because it was...
If it is a digital thermostat you must follow the set up instructions once you install the wires. Some are multi device,, which means they can be used for oil burners, electric furnaces , and gas furnaces. They have cycle programs that are different. The book will tell you which set up code to use for the type of furnace you have. If it was doing it before, it could be the primary control on the furnace itself (usually a honeywell ),,a sticking relay etc.. you need to have a technician take a look at it.
Jan 23, 2015 | Heating & Cooling
I have a steady green indicator light on my Coleman Evcon Furnace what does this mean??
Check the flame sensor is clean . And check limit control is not shutting off too soon ,
Jan 24, 2018 | Tools & Hardware - Others
I have an old unit approx.11yrs old.When turn on for heat,kicks my breakers off. It runs for about 1/2 hr. before shutting off. Tried running the emergency heat bu t, it continues to kick the breakers off...
Well, obviously your furnace is overloading the breaker it is on. Try this, turn off the breaker that the furnace is on and go through your house to make sure everything else still works. Furnaces are large power users and should preferably be on their own breaker/breakers. If everything still works then have someone you trust check the connections at your breaker box. I have had the same issue where after approximately a half hour or so my furnace would kick off.
Upon further inspection of the breaker noticed a loose connection that apparently was causing an arc and tripping the breaker. After it was tightened down I stopped having the problem period.
Jan 09, 2010 | Amana Heating & Cooling
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
Oct 19, 2009 | Holmes Products HCH4062 Ceramic Compact...
Not working properly.
REplace the T-Stat. It will solve all your problems. Also at the same time make sure your wires go to where they are marked.
R= red wire
W= white
Y=yellow
G= dont use
B=Blue
Jun 03, 2009 | Heating & Cooling
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
186 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
