Question about GE Profile Harmony DPGT750GC Gas Dryer
Converting natural gas dryer to propane.
I need to get a new (used) gas dryer and just found out that I will need to change out the orifice that controls the flow rate so that it can work with propane. My questions are "Is this part a standard size for all gas dryers (probably not) or do I need to know the specific model before I can get the right part? Also, can I get this part at a hardware or plumbing supply store?" Any help would be appreciated.
  • 1 more comment
  • ranchgirl2 Feb 27, 2009
    Thanks so much for the quick response! It answered my question exactly.
  • bozeman_just Mar 10, 2009
    I need to change a gas dryer to a propane. How?
  • sethmichelle Mar 16, 2009
    I have an admiral dryer Newly purchased four days ago. Home depot. Is there any "tricks of the trade" that i might need to know when installing new orfice to acomidate Porpane?
  • GE Master
  • 2,651 Answers
Yes youllneed to know the exact model of your dryer, then you can call the manufacture for a conversion kit. not going to be Available at hardware or plumbing supply,
Posted on Feb 27, 2009
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
Oct 06, 2013 | Maytag Neptune MCG8000AW Gas Dryer
I'm converting my natural gas dryer over to LP gas. I've changed the orifice but it is saying to close the regulator. It says the same thing with Natural gas but that doesn't make sense because it isn't...
I know from working on piles of restaurant equipment, that when you change over from natural to propane, you have to change the orifices and the regulator. Most natural gas equipment needs 3.5-4.0" of W.C. (that is, water column) and most propane gas equipment needs 9.0-11.0" W.C. The density and specific gravity of the gases are different. If it is glued so as you can not make any adjustments to the pressure, change the regulator to a propane one. Most natural gas regulators can not be adjusted to the propane pressure needed. Please be careful as working with gas can be dangerous. Natural gas is usually lighter than air and will rise but propane is heavier and will "pool" or "puddle" in low areas and can cause explosions in the right circumstances.
Dec 05, 2017 | Kenmore Dryers
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Mar 13, 2009 | Kenmore Dryers
Converting to natural gas
hi tom,
here is the service manual for your convenience.
please start with page 28 and follow from there.
please let me know if you need further assistance.
Sep 26, 2008 | Amana ARGS7650SS Gas Kitchen Range
Problem solved! I found the instruction sheet. Thanks anyway.
Aug 19, 2008 | Amana ACS3350AS Gas Kitchen Range
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to:
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Harmony DPGT750GC Gas Dryer Logo
1,448 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
