Question about Yamaha RX-V361 Home Theater Receiver
My computer is hooked up to my tv, and my rx-v361 is hooked up to the computer. the computer is showing that there is sound ( and the tv speakers work) but there is no sound coming from the amp. any suggestions?
  • dullleadsink Feb 27, 2009
    i don't know what tape 2 monitor is?
    Problem Solver:
  • 12 Answers
Check to make sure Tape 2 monitor is not turned on.
Posted on Feb 27, 2009
Yamaha rx-v361 turns on and off
If it turns off while playing, it might be tripping a overload circuit and resetting. Try it will just a couple low watt speakers connected and see
Sep 05, 2014 | Yamaha Stereo Am Fm Receiver Tuner...
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.9_9_2012_6_50_32_pm.jpg
Sep 09, 2012 | Yamaha RX-V361 Home Theater Receiver
I have a yamaha Rx-v361 i get sound when in DVD mode, SAT mode but no sound in TUNER or AUX (MP3 player) modes, i checked all the wiring in the back of the unit and everything is connected. please advise
Tuner is internal so there's no way wrong 'wiring' could be the problem there.
Does the tuner actually 'tune' a station?
If you're using V-Aux on the front panel for your MP3 player, make sure you haven't assigned V-Aux to a digital function. Page 48.
http://www.retrevo.com/support/Yamaha-RX-V361-Receivers-manual/id/2526ci758/t/2/
Jan 16, 2011 | Yamaha RX-V361 Home Theater Receiver
Yamaha RX-V361 cuts off: check SP cable
Disconnect the speakers and turn on. If your receiver is ok, it will not go into protection "check spkrs" Then connect speakers, one by one, each time make sure the receiver is off, then turn it on. When you find the speaker that's causing the problem it will go into protection. At this time, disconnect the speaker at the speaker, then turn on again, if it still goes into protection, you have a speaker wire problem. If it stays on, you have a problem with the speaker. If you have a multimeter and know how to read it, check the impedance and the resistance. Check the internal workings of the speaker, bad surround from dryrot or smoked crossovers, etc. look for the obvious first. Hope this helps
Jun 04, 2009 | Yamaha RX-V361 Home Theater Receiver
Yamaha RX-V361 DVD cuts off w/ check SP cable message
This message means that speakers are not connected properly. What is their impedance? What is the impedance set on the receiver via Advanced Setup menu (see manual)? Check if it is not short-circuited.
Try the receiver without speakers connected. If the message goes away, receiver is OK and problem is in the connection to the speakers.
Help!!!!!
Hi Linda,
It is showing two because the source of the sound that you are listening is probably stereo only thus only two sound comes out. You could try to change the mode to 5 channel stereo or prologic or dts-6channel mode in the surround mode to hear your sound in all 5 speakers. best thing to do is watch a dvd which would use all 5.
Regarding a/b yes if your receiver supports it which i think it does there should be place for it in the back of the receiver.
good luck
smeags.
Feb 19, 2008 | Audio Players & Recorders
Surround sound from Sky +
To upmix 2-channel sound (such as that in a TV broadcast) into 5.1 sound, press AMP and then SUR. DECODE until "PL II Movie" is displayed. This will give you "cinema-like" surround sound from a 2-channel source.
You can also assign this to one of your "Scenes" by following the procedure for scene assignment on page 26 of your manual.
Dec 30, 2007 | Audio Players & Recorders
Yamaha RX-V361 Home Theater Receiver Logo
166 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
