Question about Polk Audio PSW350 Subwoofer
Polk Audio PSW350 Subwoofer keep blowing the fuse
Brown resin seeme to be on the cicuit board by LINE IN and the LFE IN.
Should I replace the board
  • 336 Answers
The brown resin is glue that changed color due to heat and age. Rarely have I seen it cause problems. So unless you are having problems, No.
Posted on Feb 28, 2009
New sony receiver str-dh740 has 2 RCA plugs for sub woofer. How do I connect to psw350
only use one of the outputs from the rear of the str-dh740. and use a rca "y" adapter where you plug it into the subwoofer so that both of the inputs on the sub are getting a signal.
May 11, 2014 | Polk Audio PSW350 Subwoofer
My PSW350 has no sound
• Check AC plug and green LED onthe back; make sure outlet
is operational
• Check volume control on subwoofer
• For speaker level wire conections, check (+) on amplifier to (+) on
subwoofer and do the same for (-) to (-)
• Check that RCA line level inputs of the subwoofer are not wired from
speaker level outputs of amplifier
if problem still persist , the Sub may needs further troubleshooting
view these sample troubleshooting guide for Computer Speakers
Sep 25, 2012 | Polk Audio PSW350 Subwoofer
Polk Audio DSW Pro 500 remote doesn't"t work. I've tried replacing the battery and was told by another technician to take the sub-woofer out and make sure the cable is plugged up to the amp and the IR...
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Mar 06, 2011 | Polk Audio DSW PRO 500 Subwoofer Speaker
Got a brand new dsw pro 500 and hooked it up to a new pioneer elite receiver through the LFE input. LFE and subwoofer are turned on but the sub does not make sound.... whats up?
if there is multiple jacks on the sub be sure they are hooked up correctly simple mistake if not no doubtly a simple overlooked setting on your amp good luck you will get it
Nov 20, 2010 | Polk Audio DSW PRO 500 Subwoofer Speaker
Polk Audio PSW202 subwoofer. Replaced burnt fuse but blows the next fuse after connecting to amplifier and powering on. What else can I do?
Fuse probably went bad because either the large filer capacitors at the edge of the PCB went bad and or the final output IC mounted on the heatsink(15 pin) fried. Check the capacitors and all the semiconductor components on the board for burn marks or corrosion. You have to remove the heat sink clamp from in front of the output IC to adequately visualize its condition. In fact you might have to remove the large aluminum heatsink attached to the chassis to get a good view of the IC. If it or the heat sink clamp show signs of thermal burns you need to replace it. The IC is a TS TDA7294 mono audio amp available at Mouser Electronics. Replace the 35V 4700mF caps with 50V 4700mF caps. You will only have enough space on the top of the PCB for one of the larger caps. I mounted the other on the circuit side of the board. Note the polarity of the original caps and respect it in their replacements. The fuse is a 5 X 20 medium speed slow blow 250V 2.0A glass fuse.
Aug 17, 2010 | Polk Audio PSW202 Subwoofer
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
Polk Audio PSW202
The power supply or amplifier has a shorted component.
Nov 08, 2008 | Polk Audio PSW250 Subwoofer
Polk Audio PSW350 Subwoofer Logo
530 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
