Question about Logitech Cordless Desktop MX 5500 Revolution
Hello expert hello there expert can you please suggest what are the troubleshooting step that i can perform if the letter A and J on my Logitech MX5500 keyboard not working? should i try decryption?
  • 203 Answers
Try cleaning it before you mess with any settings.
Cause:
Your keyboard or number pad may collect dust and other deposits from regular use. Occasional maintenance helps keep the device looking clean and functioning properly.
WARNING: Before cleaning any electrical device or equipment, ALWAYS remove the device from its power source.
Solution:
  • For cordless keyboards or number pads, remove all batteries before cleaning.
  • For the diNovo Edge (a rechargeable keyboard with a built-in, non-removable battery), or any other similar device, switch the keyboard OFF before cleaning.
  • For corded keyboards or number pads, shut down your computer and disconnect the keyboard from the computer before cleaning.
Keyboard and number pad cleaning suggestions:
  • Use compressed air to blow dust and other debris from between the keys. Logitech suggests using an air duster squeeze bulb specially made for keyboard cleaning to limit the force of the air pressure.
    NOTE: Avoid using high pressure air hoses and nozzles. Excess air pressure can remove keys or cause other damage to your device.
  • Use a small tipped vacuum cleaner to remove dust and other debris from between the keys. Logitech suggests the use of a small tipped vacuum cleaner specially made for keyboard cleaning. Many come with USB power cords and can run off your PC or laptop.
    NOTE: Avoid using vacuum cleaners other than the type previously described. An excess vacuum level and/or large vacuum tip can remove keys or cause other damage to your device.
  • Use a dry, lint-free, non-abrasive micro-fiber cloth to gently wipe clean the surface of your device. Logitech suggests using cloths which are specially made for keyboard cleaning.
    Note: Avoid using dusted disinfectant cloths or cloths dampened with liquids unless specifically designed for keyboard cleaning. Many cleaning solvents, chemicals, and other liquids can cause electrical and/or material damage your device. This includes leftover residues which can eventually damage your device over time.
Additional information:
Many consumer electronics stores and online re sellers offer third-party computer cleaning kits which include dry wipes, swabs, air duster bulbs, and micro-fiber cleaning cloths. Some higher-end cleaning kits come with keyboard vacuum cleaners, and/or product-safe disinfecting liquid for dampening wipes, for use in disinfecting the surface of the device. These liquid disinfectants are supposed to be non-conductive electically; quickly evaporate from the sevice and leave no residue. Logitech suggests you make sure these characteristics are plainly stated and guaranteed on the product package. These specially made keyboard cleaning kits are highly recommended.
IMPORTANT NOTES:
  • DO NOT pour any liquids onto the device.
  • DO NOT submerge the device in any liquids.
  • DO NOT use a dishwasher, ultra-sound cleaner, or any other washing machine to clean your device.
  • DO NOT remove keys from the device.
  • DO NOT use cleaning solvents. Many cleaning solvents contain caustic chemicals which may cause damage your device.
  • DO NOT use drying machines, fireplaces or ovens (even set at lowest temperature) to dry moisture from your device.
Removing keys; submerging or pouring liquids on your device; using washing machines; exposing your device to excessive heat; or using caustic cleaning solvents may cause permanent damage to your device and will void the warranty.
Posted on Feb 27, 2009
Can't access files on external hard drive
Hello Amelia.
For your problem please connect your external drive and try these steps.
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select change letters and path
window will pop up then click on add
select any letter not in use and click on ok.
I Hope this helps. Dale
Dec 20, 2011 | Seagate 1TB FA GoFlexDesk USB20 Blk
My Sony Vaio Is Not Starting Up
Hi aleena_khan.
Based on the information you have provided, the issue might be due to the Battery or the Power settings.
As the issue might be due to the Power Unit in the Notebook, this might also be related to the Hardware problem(Power Unit).
Hence, it would be better to get the Unit examined at the authorized Service Center.
However, you may first try performing the troubleshooting steps which I have mentioned below:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C390934&fes=true&mdl=PCGK33P
The above link has all the possible troubleshooting steps.
Hence, please try performing all the troubleshooting steps mentioned on the page.
Performing the steps should resolve the issue.
If the issue still persists even after performing all the troubleshooting steps, the issue might be Hardware related.
Hope this helps.
Please feel free to contact for further information and assistance.
Aug 31, 2010 | Sony VAIO GRX550 Notebook
USER PROFILE CANNOT BE LOADED
Hi Madhusnair.
After researching all the information online, I have mentioned the detailed troubleshooting steps to resolve the issue.
As the troubleshooting steps are a bit complex, I have mentioned the link which has the detailed steps.
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
Before you start performing the steps, please backup the Registry.
Steps to backup the Registry:
http://support.microsoft.com/kb/256986
Once you are performed the Registry backup, you may go ahead in performing the troubleshooting steps.
As the above steps are regarding to the changes in the Registry, please take care.
Performing any unnecessary changes might lead to complex issues.
However, please follow the steps mentioned in the link.
This should resolve the issue.
Hope this helps.
Please feel free to ask further questions.
Aug 19, 2010 | HP Computers & Internet
TRYING TO RECOVER LAPTOP, GETTING THE ERROR MSG 10-FC 12-045D
Based on the information available online and the suggestions provided by the Computer Experts, the error might be occurring due to any issues with the Hard Drive of the Computer.
However, to confirm if the issue is related to the Hard Drive, please perform the steps mentioned below:
1) Turn OFF and turn ON the Computer.
2) Then, go to the BIOS Menu.
3) In the BIOS main menu, check if the Hard Drive is listed there.
4) If the Hard Drive is not listed in the BIOS main menu, please go to the "Boot" tab.
5) In the Boot tab, the Hard Drive should be mentioned along with the Hardware components of the Computer such as CD/DVD Drive etc.,
6) Check if the Hard Drive is listed on the BIOS main menu or the Boot tab.
7) If the Hard Drive is mentioned in the BIOS, this indicates that you can try some more troubleshooting steps, before getting the Hard Drive replaced.
8) If the Hard Drive is mentioned in the BIOS, you may try performing the Hardware Diagnostics.
9) The Hardware Diagnostics can be performed by using the Recovery Tools.
10) The Recovery Tools will pre-installed with all the OEM Computers.
11) For some Models, the Recovery Tools should also be supplied with the Recovery Discs.
12) Performing the Hardware Diagnostics will perform a complete scan for any errors or issues with the Hardware Components such as the Hard Drive, RAM etc.,
13) If there are any issues with the Hard Drive, RAM etc., they will be mentioned in the detailed report of the Hardware Diagnostics.
14) Once, the Hardware Diagnostics is complete, you may again try performing the Recovery.
15) If the issue still persists even after performing the Hardware Diagnostics, then the issue might be Hardware related.
16) The issue might be with the Hard Drive.
17) It would be better to replace the Hard Drive, if the issue still persists even after performing all the above steps.
Hope this helps.
Aug 15, 2010 | Computers & Internet
Performance laser not working
reinstall the driver for the mouse from the mouse manufacturer web page
Nov 22, 2017 | Logitech Cordless Mouse
Reinstalled windows , DVD drive is D: but so is hardrive now !
follow these steps to change the drive letter: Step 1: Open computer management by right clicking on my computer: 4595def.gif
Step 2. highlight Disk Management and then look for the drive letter you want to change. 73f7bbe.gif
Step 3. click change drive letter and select the one you would prefer for the drives make sure the one that is assigned will not be taken up so you will need to follow proper sequence to assigne the drive letters in the previous sequence. 7581077.gif
you shud be back to how it was before.gud luck
Feb 11, 2009 | Acer (4432A-002) CD-RW Burner
Ibm2366
ok here it is it is a auto repair sys from lenovo
This page has automated features! You can use the automated features on this page by installing a special, free plug-in. This one-time installation will not affect your computer's performance or compromise your privacy or security. fw.gif Install the automated content plug-in
chat.gif Just relax and let Lenovo Experts Live do it for you. Buy it now! New!
Some of these steps may not apply to your computer. Test for system startup after performing each step.
Select your symptom from the following list or continue to the Need more help? section:
Mar 24, 2008 | IBM ThinkPad T30 2366 Notebook
Hello
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 08, 2007 | Microsoft Windows Vista Ultimate Edition
Web cam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to  QuickCam Messenger Personal Web Camera  is unable to detect  . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I recommend you to try below solution.
Please open below web link:
http://tinyurl.com/2dgvb8
This will open a new window, the page title as" Troubleshooting".
Please perform the steps that are mentioned in the web page. The steps are related to your issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 18, 2007 | Logitech QuickCam Messenger Web Camera
Logitech Cordless Desktop MX 5500 Revolution Logo
264 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
