Question about Konica Minolta bizhub 250 All-In-One Laser Printer
I have an error code c-3C50
Any advice
    Problem Solver:
  • 12 Answers
Google that code or go to Konica minolta web page and go to support or service manual and find that code
Posted on Feb 27, 2009
What is f4 and f7 error code
F04 Error code is "Pressure switch jammed on empty"
F07 Error code is "Heater relay stuck"
Both would require you to dis-assemble the washer to get to each part for checking / replacing.
http://www.hotpointservice.co.uk/help-and-advice/error-codes/
Sep 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
Konica 8020 3c50
if the code is C-3C50 you have a big problem!!!!!!!!!!!!
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips..
You machine is also a legacy Konica machine so I don't know what Konica Minolta technician will do.
Apr 05, 2014 | Konica Minolta Office Equipment & Supplies
612 fault code
Technical Advice: 0870 241 8180 try this number very hard to faulty code this there phone number for Technical Advice
Jan 07, 2012 | Heating & Cooling
When i turn on my printer cf3102 error c-3c50 came up and printer doesn t work i have to restart it to solve problem?> what s the cuse?
you can take a look at this thread:
http://www.thecopiernetwork.com/printthread.cfm?Forum=124&Topic=17881
Oct 28, 2010 | Office Equipment & Supplies
I have installed a used Kyocera KM-C2030 printer and getter error
the drivers for and instructions for networking can be found on usa.kyoceramita.com under the downloads section and this copier is a legacy copier... this is a kyocera name with a konica body here is the link to fix the issue
Oct 25, 2009 | Kyocera Mita KM-C2030 Printer
Minoltacf3102 with 3c50 error
HI,
It is a scanner problem.
On the scanner pcb you have to solder an electolytic condensator of 100uF 25 volts
over the C 143 capacitor (watch out to use the right polarity)
Marc
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
Minolta Dialta Color CF 2002 MAL FUNC C-3C50
c3-c50 is a money bank code. It means that someone tried to copy money on the machine. U need a minolta code to reset it for good but it works by just opening and closing the front door, certainly the code will reappear.
Apr 25, 2009 | Minolta Office Equipment & Supplies
Konica minolta bizhub
Your not giving enough information. But i would make sure that the interface cable between the optics and the print engine are intact. Its the fat cable with the high density pins on the right side of the machine near the back. (external) Make sure this is reseated, otherwise you will be tearing into control boards.
Nov 23, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
678 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
