Question about Vtech Cordless 6041 Phone
Static on handsets unles I am speaking or there is other sound in the room.
    Problem Solver:
  • 10 Answers
If you have DSL , Make sure you have a noise reduction filter plugged into the jack before you plug the phone into the filter.
Make sure you plug your phone on the "Phone" side of the filter not the "Data" side.
Posted on Mar 01, 2009
Basically we are getting a static sound every now and again. I think it has to do with the wireless signal because it only happens when the room is filled with people not when the room is empty. How can...
Try moving belt pack around on person (speaker) and try moving receiver closer to person speaking, also keep receiver elevated, off floors and antennas need to be up. Wireless signal is like "line of sight" and if there's a ton of obstructions you're cutting signal strength. Also make sure you ALWAYS use fresh batteries, weak batteries will do the same.
Feb 25, 2011 | Sennheiser MKE105S LAV MIC w/PIGTAILS -...
Can't find my manual. How do I get the messages off the phone, it's a Magicbox Logan three dect thingy.. Also how do you get a conference call happening?
Hi
To delete messages you need to first listen to them all on your machine via the BASE, then after all the messages have been played (which can be very boring) press and hold the DEL button. It will then ask you to confirm deletion by pressing OK. Not too sure about the conference call as mine does not have it. If however someone else in the same room wants to listen to the caller you can press the handsfree button (speaker icon) on BASE. If you want to speak to someone within your household in another room, you need to press OK on HANDSET, then press down to INTERCOM, press OK again and it will give you several options, INTERCOM ALL (where all available handsets can talk to each other), or HANDSET 1 or 2 to select a specific one. Hope I have helped and it does not sound too gibberish!
Regards
Feb 04, 2011 | Lands Phones
I have a Philips Model PET702/37 DVD player. It has constant static in the speakers, even if I have the DVD player on pause. I can't hear the person speaking on the DVD and it is VERY annoying. Can you...
It sounds like that you might have a high voltage arch or a bad connection on the audio amp board. You can take the back off and with the lights off, or in a dark room you can look for something arching.
Nov 11, 2010 | Philips PET702P/37 Portable DVD Player
I can't hear any sound in yahoochat room and i can't speak in yahoochat room
Make sure that your sound is turned on on both yahoo chat and your computer and that you have a microphone to speak into for them to hear you
Nov 11, 2010 | Yahoo Messenger
I have a Uniden set of of phones - 5.8 GHZ. Both are making a loud static sound when you turn it on. We can hardly hear. We unplugged both sets for a while, but this did not get rid of the static sound.
• Keep the handset away from microwave ovens, computers, remote control toys, wireless microphones, alarm systems, intercoms, room monitors,fluorescent lights, and electrical appliances.
• Move to another location or turn of f the source of interference.
Dec 31, 2009 | Uniden 5.8GHz Cordless Phone
Beocom 2400 earpiece soundcable problem
Hi I also had a problem with the wires breaking on the handset of my Beocom 2400 , and I could not find out anything on the Internet .
But I managed to fix it without to much difficulty !
So I thought I try and help people in the same situation out !
Anyway to split the handset you will need a plastic card , like a credit card , store card etc) as in picture . DO NOT USE anything made of metal !!!
You will need to start at the bottom of the handset where the microphone is ,on the right hand side looking at the front of the handset .Insert the card,only a little way about 10 mm, then draw the up where the seam is , once it has started to separate you will find it will become easier as you work you way round .
Once you have separated the two halves you then need to peal the outer casing off the cable find the break cut it out and solder the wires back together ,I used heat shrink to cover the bare wires as in picture .
When you have done this it is just a case of sticking the two halves back together , Don't use instant glue!! use a glue which will give you time to position the two parts as it is not that easy , then clamp the two parts together with cable ties , as in picture .
Clean off any glue ,leave for glue to set remove cable ties , job done .
I hope this has been of help to someone!
Regards Stuart . dorsetpicture.co.uk .
http://farm3.static.flickr.com/2460/3814339247_8767c2aa31_s.jpg
http://farm3.static.flickr.com/2444/3814339347_83180a9499_s.jpg
http://farm3.static.flickr.com/2513/3814339477_9577cf01d2_s.jpg
http://farm3.static.flickr.com/2447/3814339721_72d7e68176_s.jpg
http://farm4.static.flickr.com/3556/3814339799_b30d7d805a_s.jpg
http://farm3.static.flickr.com/2461/3815149182_c31a69fc0c_s.jpg
I take no responsibility if you bugger it up ....
Jun 16, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Heavy Static on phones. Can't hear caller. No caller ID
Room monitoring mode is basically a type of Intercom.
Press the *TONE/exit button on the handset to exit room monitor mode.
I will provide you with link to the user manual of the phone. Have a check at it. Might be useful.
http://www.home-electronics.net/ge/pc/IB/28112EE1_IB.pdf
May 30, 2009 | GE 28112 Trio Cordless Phone
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Can only dial 9 or 1, 2-8 keys not working
it sound to be block but thats my personal opinion due that I dont work with that brand, there are few other brand model that have that feuture just to have controls of the use of the phone, they use to recive only but allowe to call 9-1-1..unles no other tech tell you something else try to get the manual of that unit..good luck
Jul 27, 2006 | Vtech VT-2431 Cordless Phone
Vtech Cordless 6041 Phone Logo
186 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
