Question about IBM ThinkPad A30 2652 Notebook
My laptop won't work
I have an ibm a30 thinkpad it doesn't work
  • 113 Answers
SOURCE: Ibm thinkpad A30 2652
Some of the older thinkpad had a program you from the OS or a boot floppy to had to run to get change the bios settings. But the BIOS key on most is F1. So if you press that key as soon as you turn the machine on and anything appears on the screen, and once you've provided the password you can then change the password to blank within the bios.
If you don't know the password at all, there may still be a way to reset it, but it may require a call to IBM/Lenov, or some other tedious process.
Posted on Feb 02, 2008
  • 63 Answers
the new video drivers require your Thinkpad to have BIOS version 1.14 or higher so update bios or download an older ati driver.
Posted on Jul 08, 2008
  • 211 Answers
ThinkPad A30, A30p, A31, A31p (MT 2652/2653/2654) and ThinkPad Dock (MT 2631) Service and Repair Manual
Posted on Apr 13, 2009
  • 358 Answers
SOURCE: IBM A30 Thinkpad won't start. Press power on,
Even though a lot of things might have gone wrong and caused this, especially if where you place the laptop is not well ventilated, and the CPU becomes very hot.
It then shuts down automatically...and you will have to wait for a few moments, get a cool environment and power it on.
But I will also try and tell you some troubleshooting steps that you can try.
First of all, disconnect your battery from back of the laptop, and try to power your laptop without the battery there, if it powers up, then just get a new battery.
Second, get a screw-driver, remove all the RAM(memory sticks) at the back of it, clean their interface with an eraser, and try to power it on first without them, then replace them back and power it on.
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
Next, try and get a friend or a technician that uses the same type of laptop, and try to swap the battery just to check whether it powers it.
Kindly Let me know how it goes.
Hope this helps.
Posted on Dec 16, 2009
  • 32281 Answers
SOURCE: Ibm thinkpad A30 doesn't receive power from new or
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jun 30, 2010
How can i reset bios password of ibm thinkpad A30 2652
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Feb 02, 2011 | IBM ThinkPad A30 2652 Notebook
My IBM thinkpad A30 cant play sound after i formatted it
Here is a link to every driver you may need for your laptop!
Here is a link to your audio driver (assuming oyur using Windows XP)
No sound is most definitely a driver issue, so give me a thumbs up if these links help you!
Jan 02, 2011 | IBM ThinkPad A30 Notebook
Dose all ibm have wireless connection in them
No all ibms dont have wifi built in,,check ibm website to see if your model does,,also jus search online ,,,ibm thinkpad a30 2652 did it come with wifi,,should find answers,,thanks,,goodluck
Nov 20, 2010 | IBM ThinkPad A30 2652 Notebook
hola cual es la solucion para desbloquear mi laptop IBM A30
Oct 24, 2010 | IBM ThinkPad A30 2652 Notebook
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
Jul 08, 2008 | IBM ThinkPad A30 2652 Notebook
Hi sir.. can u fix my ibm thinkpad A30
Here's a link to IBM's video drivers. You might have to try several before finding the right one. Keep in mind that it doesn't have to have your particular model listed in order to work properly.
Jul 08, 2008 | IBM ThinkPad A30 Notebook
IBM ThinkPad A30 2652 Notebook Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
