Question about Microsoft Xbox 360 Console
The Xbox doesn't start
The xbox has a red ligh blinkingt in the position between 3 and 6 o'clock, on the start button when we turn it on.
There is no way to fix this problem but if you call the xbox company and tell them about the red rings they will send you back a new consel but they will send your old memorycard back
i had the same problem
Posted on Feb 27, 2009
I went to turn on my xbox wireless drum kit and the light just came on for a second and then went out so i replaced the batteries, several times but it still wont come on
Well you can try this solution to get it too work. The thing with the XBOX 360 is that it has a hard time syncing with other controllers made by different companies. So try these steps first and see if they work if not you might have got a set of bad drums.
Step 1. Turn on XBOX 360 Step 2. Turn on drums (hold xbox button on drums). Step 3. Press sync button on 360 (XBOX ligh on console should start circling Step 4. Press sync button on drums [under D pad] (xbox light on drums should start circling)
If this doesn't work then you should RMA the drums to http://rockbandservice.ea.com to replace the bad ones.
Apr 23, 2011 | Activision Xbox 360 Guitar Hero II
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I got 3 red lights after using it for a couple hours then 2.
My xbox is not working the lights on the start button is flikering & the lights around the center are flashing in a counter clock wise ring?????????????
Mar 02, 2010 | Microsoft Xbox 360 Console
Iplaying my xbox when flas red ligh but I connect other control after turn off I disconnect and connect but not more work
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Jan 18, 2010 | Microsoft Xbox 360 Console
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Oct 26, 2009 | Microsoft Xbox 360 Console
Switch on xbox withing 5 seconds a red ligh appears bottom right but if you turn the xbox on ots side the red light slips to the bottom right no sinal to television
This is the video chipset failing, couse: heat problem, the main board expands by the generated heat then cousing the solderings of the video schipset to brea, get the xbox to a repairs man.
Aug 28, 2009 | Microsoft Xbox 360 Console
Flshing red light
It needs the 3 red light fix. We can fix this for you contact us at xbox360fixer@verizon.net
Jan 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 not on ,its flash red light
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 17, 2007 | Microsoft Xbox 360 Console
3 flashing red lighs??
3 red lights is the red ring of death your system has basically melted. your gpu overheated and is now not working. If your system is under warrany i would send it in and get it replaced Call MS for that.
If you bought it from like best buy with a replacement plan they will give you the purchase price back and you can do what you want with it.
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Mike Neath
Mike Neath
Jonathon summesfield
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
