Question about GE DBSR453EBWW Electric Dryer
Intelli sensor doesn't read that clothes are wet,just damp.does not get clothes dry in intelli cycle.does get them dry in timed cycle.already replaced sensor.
  • 686 Answers
Do you stack clothes on top? If so take them off and try another load and never ever put anything on top. It insulates it and makes the dryer not run right. Good Luck
Posted on Feb 27, 2009
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't...
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Sep 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
I have a Bravos clothes dryer and when the cycle is finished, it is very damp, wet and the clothes are not dry. What can I do?
This dryer automatically starts in the "sensor dry" mode. DO NOT use the "sensor dry" mode - use the timed cycle where you manually set the time. The sensor is in the back of the drum, and it frequently misreads the wetness of the clothes, especially if there is a t-shirt or something light in the back and towels or something heavy in the front (near the door). If you are still under warranty, you can have the sensor replaced (or purchase one), but it only helps slightly.
Oct 18, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
How does may tag intelli dry work? what is the difference between less and more heat setting
there is a sensor inside the door to the right it actually "feels" the dampness of the clothes across the two strips on the sensor, if you close a wet washcloth in the door so that it hits the sensor you will see that it will show as wet and it will run longer.
if nothing in the load hits the sensor the sensor will call it dry and the load will finish, larger loads work better with sensor dry small loads not so much. if there is alot of trouble try using the timed dry cycle.
Sep 03, 2009 | Maytag PYE2300AY Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
218 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
