Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
WHAT ARE SETTING ON POULAN 2375 CARB. - Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
    Scholar:
  • 149 Answers
Start at 1 turn out on both
Posted on Feb 27, 2009
Routing fuel lenes from carb.to primer bulb to tank and back to the carb.?
moz-screenshot.gif/www.ereplacementparts.com/poulan-2375-type-gas-chainsaw-parts-c-16962_17147_17263.html this will give you a good break down. select diagram B and you will be looking at figures 6, 12 and 14
Aug 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to conect fuel lines to poulan chain saw 2375 Le
The hose coming from the fuel tank with the filter on the end goes to the fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, now take a hose from the other conection on the carb to the shorter ( suction side ) conection on the back of the primer, take a hose from the longer conection ( pressure side ) on the primer back to tank, this just pushes into the tank, just remember that the primer pulls fuel from the carb and dumps it back to tank.
Apr 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 2375 will not idle
This sounds like a simple carb adjustment issue, however there is a special tool required to adjust the mixture, part no. 530035560, once you have the tool richen the L scerw on the carb by unscrewing it by 1/4 turn out, before making this adjustment, try just increasing the idle speed screw on the carb, this requires just a normal screw driver, do not increase it to the point ehere the chain is moving on idle.
Mar 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a routing map of the fuel lines for the wildthing 2375
There is no diagram that shows this, however i can tell you where they go, the fuel hose from the tank with the fuel filter on goes to the fuel inlet on the carb, the nozzel nearest to the pump side of the carb ( cover held with one screw ) the pipe from the carb nearest to the metering side ( cover held with four screws ) goes to the suction side of the primer ( short nozzel on primer ) there is then a pipe from the pressure side of the primer ( longest nozzel on the primer ) back to the tank ( just pushed into the top of the tank ), just remenber the primer pulls fuel from the carb, and dumps it back into the tank.
Mar 02, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan WT usually starts Ok but after it is used for 8-10 minutes it cuts out when when trigger is released. Happens mostly when you're cutting & then release trigger when cut is done.
If the carb hasn't been rebuilt in a few years, often the fuel pump diaphram gets weak or the little flap check valves get deteriorated. Carb kits are about $20.
Feb 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
It cuts out at full throttle.
Check the muffler and air cleaner for plugging. Try turning the H jet needle CCW about 1/2 to 3/4 turn which should make it 4-stroke at full throttle. Proper setting is for the engine to 4-stroke at full throttle, but immediately 2-stroke when cutting. (CW turning of H makes it leaner) See a Poulan servicing dealer for a rebuild kit. Be sure to check the fuel filter in the tank for plugging. Hope this helps!
Apr 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Mar 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
390 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
