I experience frequent disconnection from my Internet connection whenever i connect out of the wireless router.I keep getting connected and then disconnected to the internet. Please check and assist as i have already updated my firmware and also how do i retrieve the password...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
SOURCE: frequent disconnection of internet service
HI rodelio,
Please give me the backbone of your committed internet rate (CIR), is it burstable bandwidth? Actually router is designed for Network Address Translation (NAT) which means it is better to have fast ISP that has committed internet rate (CIR). It is constantly happened for internet connectivity fluctuation cause of very low CIR specially when you are connected with more than 3 computers on the network setup.
Much better to used proxy server with linux, or Kerio Route Firewall for better performance of your browsing.
I am glad if you can extend your problem to me. I am here to help you.
Best regards,
Philip
SOURCE: My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
SOURCE: ASUS WL-520g wireless router and hutchison broadband connection problem
You need to contact your ISP if the internet connection is not there....
SOURCE: Belkin Router keeps frezing.
Try changing the channel of the router to 1,9 or 11, and make sure that there is no cordless phone near the router or the wireless computer, this will help mionimize wireless interference. If this may not work you may want to adjust some settings on the advance wireless settings of the router like the beacon(set it to 50) and RTS/fragmentation(2304).
SOURCE: Cannot Set Password for Security on Edimax Wireless Router
Try to download the manual from here:
http://www.edimax.com/en/produce_detail.php?pl1_id=3&pl2_id=18&pl3_id=43&pd_id=261
and just have a good read?
Merry Xmas
