Question about Maxtor Hard Drive
IDE drive install in SATA computer
I have a Maxtor 5T040H4 IDE drive that I would like to install in a newer compter that that is set for SATA drives. There is an IDE interface for the DVD and DVD r/w, so my thought was the BIOS should support IDE. I installed an Ultra ATA / 100 PCI adapter card to provide the PATA interface for the 5T040H4. The card is recognized at system startup, but then I get a message that there are no drives attached (and some buzzing / chirping even though the onboard PC audio is turned off). When I go into the bios to see if there is an option to acivate the drive, there are on-off options for SATA 0-3 and the two DVD devices. Am I trying to do something that just won't work? I've tried all the combinations of master / slave jumper and cable postions I could think of.
  • 203 Answers
Can you remove a disc drive and use the hard drive in the original ide slot?
you pci adapter may not work with your motherboard, not all cards are compatible with all boards.
Posted on Feb 27, 2009
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Can I use a Maxtor DiamondMax Plus 60 (5T040H4) 40.9 GB like Slave?? Thank you
Of course you can use it. Put the jumper to set the configuration as "slave" and insert the a plug from the ide cable. If you put the put the jumper to "cable select", put the slave plug and it should work great.
Mar 15, 2010 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
Oct 07, 2009 | Maxtor Hard Drive
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Jumper setting
Put the jumper on J50(the closest set of pins to the IDE connector)
This will set the drive to master, with no pins on it's currently set to slave.
Chris
Oct 21, 2008 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
Problems installing a SATA hard drive
Hi Tony. As you are using a SATA hard disk then I would firstly check a few settings, this involves loading the computer BIOS. When you see the computer first turn on, you should be prompted to press "F2" to enter the BIOS screen.
From here select "Enter BIOS SETUP UTILITY" then "Advanced screen" and finally "IDE Configuration"
Verify that 1) Onboard IDE Controller is set to "Enabled"
 and          2) “SATA Operation Mode” is set to "[non-RAID]"
Once you have done this, you should see the HDD listed beside SATA 1 or SATA 2 (depending on which port you plugged the hd in to) then press F10 to save and exit. The computer will now start up as normal.
If you have more trouble after checking these settings, please write us again.
Hope this helps
Apr 09, 2008 | Maxtor Hard Drive
SATA problem during windows install
try other memory or if you have 2 dimms take one out and try same to both dimms
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Maxtor Hard Drive Logo
189 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
