After loading and setting the control dial, the lights on the panel light up as they are supposed to but when you press the start button nothing happens. So far if you press all around on the button it will finally start. Something is about to go bad. Which part may be causing this?
SOURCE: ge wssh300 front load washer starts final spin
The
spin problem could be a number of different things,one, the motor is
bad, two your belt is bad, three the clutch is slipping, but as far as
the suds goes how much detergent are you using and what kind? is the
cold water coming in full force on rinse? if you have allot of suds
this can make the machine not spin fast also.
The clutch is the most likely cause,these are not cheap, in fact it comes as the motor and clutch together on this.
If
you are looking for a good reliable machine buy a top load direct drive
whirlpool, no frills or bells and whistles and these run great for a
long time and when they need repair these are inexpensive to fix. thats
what i recomend.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: I have a front load
How to clean the filter
Technician's Service manual
I believe your pump filter is clogged. Use the links above to help you save some money.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
