Question about Roper REX4634KQ Electric Dryer
DRYER NOT HEATING
MY DRYER IS WORKING BUT I HAVE NO HEAT COMING OUT OF THE HEATER COIL WE CHECK THE FUSE WE ALSO CHECK THE THERMASTAT SWITCH AND WE HAVE NO JUICE COMING FROM IF
  • Roper Master
  • 1,230 Answers
Simple. The thermostat is nothing more than a temperature activated switch. If power goes to it put not through it when it is cool, changes are it's DOA. Don't overlook checking the heating elements while you got the unit apart. May save yourself some trouble down the line.
Good Luck
Posted on Feb 27, 2009
Whirlpool WED9500CT1
Be sure all controls are set correctly and door closed.
Be sure door switch is good.
Be sure you have 220 volts at power block in dryer.
remove cover and check with voltmeter .
Check heating element with ohmmeter.
Check from heating element to heater box to see if grounded.
Check thermal fuse & thermal cut-off with ohm meter.
Check all thermastats with ohm meter.
Check centrifugal swith, in motor.
Apr 23, 2013 | Whirlpool Dryers
Dryer is working but no heat
Electric? Check the heater element then the thermal fuses or on the newer units, thermastats
Jan 05, 2013 | Whirlpool Dryers
Dryer will run with no heat
Hi bmoral...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Aug 15, 2011 | GE DBSR453EBWW Electric Dryer
Heating element not coming on how do i check the thermastat
Hi akcaceres...
Check your Wiring
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
This is a FREE answer, Please take time to rate me
Jun 26, 2011 | Dryers
Dryer works fine but does not emit any hot air.
First check and see if it is on heat not on a cool cycle on timer. If ok then check thermal fuse and thermastats then check the heater coil. Hope this helps.
May 03, 2011 | Whirlpool CAM2752KQ Top Load Washer
My dryer is about 7-8 years old. It has been taking longer to dry clothes for a little while now but within the last few days will not heat up. Spins fine, just no heat. Breakers are good.Any solutions?
Have you cleaned the blower vent pipes lately. Sounds like the vents may be stopped up with lint and it got too hot. Clean vents and where the fan blade is to be sure the fan can turn. I have found everything you can think of in the blower housing that would keep the fan from turning.Be sure and get the lint out they all have some. As far as the heat not working check all thermastats , the thermal fuse on blower box and thermal cutoff usely on the heater box. and the heater coil also check with an ohmeter from heater coil connections to the metal box it's in ,the coil could be grounded inside the box.
Hope this helps.
Dec 05, 2010 | KitchenAid Dryers
MY DRYER WAS NOT HEATING AND I REPLACE THE ELEMENT, THERMO FUSE, AND THERMASTAT, AND IT IS STILL NOT GETTING HOT. WHAT COULD BE THE PROBLEM?
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater /thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
This is a free answer, Please rate me
Oct 02, 2010 | Whirlpool Dryers
The dryer is no longer heating up to dry clothes. it was fine one load ago and now it's not working. the coil is not clogged and there was no excess lint blocking anything.
The first thing to check is the power coming to the dryer. If you have fuses instead of breakers, make sure both fuses are good. Even if only one is bad the coils wont heat up. If you have power, then check the small "cricket" switches inside the rear cover to the dryer. To check them, unplug the dryer, locate the small disk(s) with wires connected to it that is attached to the housing for the heater coils. unplug the 2 wires, then check the disk with a continuity tester or ohm meter set on ohms. there may also be a fuse with 2 wires ( about an inch long fuse) attached to the heater housing, check it for continuity also. the fuse is usually the problem, but not always. Hope this helps . Robin
Jun 10, 2010 | Whirlpool GEW9250 Electric Dryer
Neptune dryer proble. The dryer works except no heat. Flame starts, but then turns off. Igniter element was checked and is good. What else should I check in order of probability? - flame sensor? -...
Hi
Thanks for using FixYa. Things that could stop an electric dryer from heating: - house fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Roper REX4634KQ Electric Dryer Logo
67 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
