Question about Belkin (F5D7230-4) Router (587009)
My NAT type is modrete
It tells me that i need to open NAT conf, and that if the router support UPnP
  • 708 Answers
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Posted on Feb 17, 2010
Hello i got the zyxel p660hw-d1 today and its imposible to have open NAT even using DMZ or Upnp, NAT is always moderated. Any solution? thanks
First you must tell me what you are trying to do... becaus you talk about OPEN NAT (i'm not an expert in gaming) but in th network world NAT stand's for Network Address Translation from the WAN side of the router to the LAN side... and Upnp is a protocol, nothing to do with DMZ (DeMilitarized Zone) which involves opening ALL ports in the FireWall of your router to a specific machine on the LAN side....
Dont forget opening ports is opening doors to hackers... (I think the term NAT in the gaming world has some thing to do with controlling access to other players) post me if i'm wrong!!!
Cheers!
Apr 07, 2011 | Zyxel P660HW-D1 Router
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
I have hughesnet modem hn9000 and a netgear router. I am unable to connect to the internet with anything more then a nat type 3. I need @ least a nat type 2 to game. Any suggestions?
What you need to do is turn on uPnP (universal plug and play networking) this will provide an open firewall for gaming.
You need to login to the router as an administrator and ensure enable uPnP is enabled. It is often on the security screen for the router.
Please let me know if you need additional detail to help you set up your router.
Dec 27, 2010 | Computers & Internet
How do i open my NAT type? i have moderate NAT type and i wish to open it, how to do so?
login to the router and enable uPnP - it should be on the security screen. if you don't have uPnP as an option you will need to use port forwarding rules. These depend on the application reporting the moderate NAT.
Let me know if you need further details on how to get into the router.
Dec 18, 2010 | Arris SURFboard SBG900 Wireless Router...
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
L can get into xboxlive but it come up your nat type is strict peopleon network with this nat type may not be able to join certain games or hear other people while playing online for the best online...
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Apr 08, 2010 | Microsoft Xbox 360 Elite Console - Black
Trying to set NAT type to open so I can play on Xbox Live without any problems.
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the
router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the
settings of the router
Make sure that the UPnP is enabled on the router.
Click Here to know more about router and network
Jan 30, 2010 | D-Link DGL-4100 Router (DGL4100)
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
Belkin (F5D7230-4) Router (587009) Logo
493 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
