Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
8hp Tecumseh will not fire.
My kids have a Murray go kart with a 8hp tecumseh motor that will not fire at the tip of the plug wire. What would be the problem?
  • boogs1221 May 13, 2009
    I have a 8 hp tecumseh motor on my yard machine riding lawn mower. It sat for 2 years in a garage so I replaced the battery but it will not fire I dont know much about motors. Can someone please help me. Here is the model of engine if that helps Tecmuseh 8.0 hp tvxLL 95-150259
HW_Dude
  • 87 Answers
SOURCE: tecumseh 8 hp problems
I had exactly the same problem, I tried to clean the carb several times without any luck. I gave up on the carb as it was an EPA style without adjustable mixture needles. Bought a new carb for it, installed it and the engine fired up right away. Took me 10min to let it warm up and dial the mixture, it has been fine ever since.
I recommend to buy the replecement carb old-new stock mfg pn: 632334A Tecumseh Carburetor with mixture needles
This place helped me out with one.
Posted on Jan 17, 2009
  • 67 Answers
SOURCE: tecumseh 8 hp tvm220
it is a standard magneto fired engine --- go on line and google up magneto
Posted on Jun 22, 2009
  • 153 Answers
SOURCE: gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Posted on Sep 27, 2009
  • 4 Answers
SOURCE: tecumseh vantage 35 carburettor
Here's an exploded view: http://www.lawnmowerparts.co.uk/partfinder_pview.asp?pID=1739
There's a picture here of your carb on a qualcast mower: http://chat.allotment.org.uk/index.php?topic=58598.0;topicseen
I hope that helps
Posted on Jun 25, 2010
  • 760 Answers
SOURCE: Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Posted on Jul 04, 2010
Can you replace the whole spark plug wire on the coil on 8hp Tecumseh without changing the coil
Not unless you cut the wire and splice a new piece on, which I would not recommend. A new coil should cost you less than $20 and is not hard to replace. See the attached YouTube video on how to do it. https://www.youtube.com/watch?v=v6bQrNr4lv0
Feb 26, 2015 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Need to find correct spark plug for Troy-Bilt #42027 Snow Thrower.
Several engines were available, you need to look for the number on your current plug - easiest method.
otherwise, you will need to give the motor manufacturer and nameplate info (Tecumseh SnowKing 8HP?)
Nov 16, 2014 | Garden
I have a Murray 30" riding mower with a Tecumseh TVM195 8hp engine that won't start. The engine seems to be locked. I have removed the spark plug and tried to turn it, but it is still locked tight. The...
Maybe the rope pull start is stuck? Remove shroud and see if you can rotate the flywheel by hand. If it won't move then the crankshaft may be stuck on a broken part, such as the governor gear or camshaft that has broken off.
Aug 04, 2014 | Murray Garden
Tecumseh 8hp drive stopped have to push
Could be the belt is broke or come off or the pully loosened on the shaft. Good Luck
Jan 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
5.0hp tecumseh power sport wont start
you have to take the bowl off the carb and see if the Jets are clogged.
How long did it run before you shut it off?
Oct 04, 2012 | Garden
I need components for reparation motor of roto-hoe model 990-5, hm 80. If you can help me I would be thankfull
I have one of these beasts on an old go kart, governor is broken or something, rebuilt it a couple years ago, I have picked some bolts and such off it, have a brand new carb pretty much, what exactly do you need? It was a strong running engine, but at this point it's too dangerous for the kids and I'm done dealing with it.
Jun 25, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a 6hp tecumseh motor on a go kart that is not getting spark.it has been sitting for a whilei have cleaned the magnet behind cover but im not sure if it is the problem or something with the on/off...
First, try a new plug, then if still a problem ....
Assuming it's not pre-1985, then the ignition is solid state. To test - disconnect the 'kill' wire (usually black, but could be green or even red) coming from behind the cowling. Check for a spark. If OK, your problem is in the wiring. If still no spark, replace the coil.
If your engine IS ancient enough to have points, post back here and I'll advise.
Jul 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
791 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
