Question about HP Wireless Optical Mouse
Nothing works on it
It worked great then I droped it off the chair on to carpet. Now the arrow will not move and nothing works on it. I checked the battery. not the answer.It is new I had it for one day befor this happened. I'am a computer dummy.
  • swumom Mar 14, 2009
    I have a new wireless mouse, used 1 day, knocked it off onto the carpet and now it doesn't do anything. Please help! Thank you
  • 239 Answers
Try resyncing the mouse to the wireless reciever. if that doesn't work then it sounds like the mouse was damaged in the fall as mice are not very durable this can happen easily. the store should not be able to tell that you dropped it and will probably return it for you.
Posted on Mar 01, 2009
It won't power off or move
If nothing looks broken on the joystick the batteries may have become disconnected when the chair hit the ground. Check all wiring connections on the chair. You can test to see if there is voltage getting to the joystick with a voltmeter.
Oct 02, 2015 | Health & Beauty
Chair shows full charge, or most of a charge (depending on how long it sets between looking at it), and has limited mobility for a while, after sitting turned off for several hours.
Hi if the batteries r 5 years old it would be a good idea to replace them ...u can't rely on you're charging circuit giving u a true reading on the condition of you're batteries they have to b tested with a BATTERY LOAD TESTER they put a 100 amp load on them this will give u a true reading on the condition of you're batteries ..cheers
Sep 10, 2015 | Pride Jazzy 614 Hd JAZZY 614HD
Does riding my wheelchair on carpet wear the battery quicker?
That question has a yes and no answer. If the carpet does not create alot of resistance then probably not. The best way to describe what I am saying is if you can roll something that has small wheels like a microwave stand across the floor with a small amount of effort then your wheelchair isnt working too hard to move across that carpeted floor. If the carpeted floor is real soft and cushioned under your feet your chair will have to work a little harder. Any time you are not rolling on a hard surface your chair will have to work a little harder than it would on the harder surface.
Aug 05, 2014 | Health & Beauty
Chair wont turn on
sounds like the power is not getting through, check the batteries are they charged? if not there is prob a loose lead or battery needs to be re fitted to be sure they are making proper contact.
Nov 20, 2013 | Jet 3 Ultra Power Chair
Chair was working fine. Then it was plugged in for several days. LIghts come on, but chair will not move. Can batteries be over charged? We did push reset button in front, but that did not make any...
Evonne the batteries were probably overcharged you should never leave it charging for more that 12 hours Check that the freewheel levers are in the drive postion they are two levers under the front of the seat. They should be pointing toward the center of the chair. If they are in the drive mode then there are other problems. Contact Roadrunner Mobility @ 1-800-467-2668 to see if they have a tech that can come out to check the chair Medicare will pay for most of the repair cost if they paid for the chair. Hope this helps
Mar 01, 2011 | Jet 3 Ultra Power Chair
How do I calibrate the scale
Make sure the chair is clean and there is nothing between the chair the sensors. Put the setting to zero. if it the arrow goes to center you are good. if not you have to adjust the screw on the other end of the beam. Make a quarter turn at a time. Don't go crazy with it. Try to get the arrow to zero as close as possible. push down on the chair a few times times to make sure it is consistently gets to zero. Get several different weights to check the linearity, 10 should equal 10. 20 should equal 20 and so forth.
Nov 10, 2010 | Detecto 475 Beam Chair Scale
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
Jazzy 1113. The chair was doing great. The user passed away,
Naw the batteries are shot Get yourself two U1 batteries from a battery warehouse or store that sells batteries around $200.00 for two
Jul 23, 2010 | Pride Jazzy 1113 Power Chair
Chair fully charged lrd lights flashing and chair wont move
Try using a Voltage meter to test the Voltage coming from your batteries. Your batteries should be as close to 12v. your motors are 24v. Even if just one battery is bad this can cause alot of headaches.
Jun 20, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Chair will not go up or down
The clicking is the mechanical part of the switch, but the electrical part may still be bad. In all the chairs I have serviced, it has always been the switch. The switch itself goes for about $25 plus labor to change it, and the whole control unit retails for about $100. the best test is to take the controller apart and short out the center wire to either side and check the chair for movement.
Jan 22, 2009 | Pride Mobility Products Casual CL30KD Lift...
HP Wireless Optical Mouse Logo
142 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
