Question about Maytag MED9700S Electric Dryer
Maytag MED9700SQ0 front load dryer lights but doesn't run.
Lights up like normal but when start button is pushed it just clicks once. No blower, no drum turning but it counts down. Turned off at circuit box and retried with same result. Holding start button down has no effect.
  • Anonymous Apr 24, 2009
    I am having the exact same problem. I hit the start button. It comes on and then beeps once. The 'sensor' light comes on and then nothing happens.
kevin000
  • 1847 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
The control panel seem to have the problem.
Posted on Jul 14, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
  • 142 Answers
SOURCE: Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Posted on Jun 03, 2009
  • 1218 Answers
SOURCE: Maytag Dryer won't start withouth me turning the drum.
Good day. Ugly problem.
My first choice would have been the motor, but.......
Here is the process, it might help you.
The power to the motor goes first to and thru the door switch. It then returns to the timer.
When the timer is turned to any running position, power leaves the timer where it is split into 2 leads.
One of the power leads goes directly to the centrifugal switch Which is the switch on the motor with all the wires. If you spin the drum, you also spin the motor, and if spun fast enough will close the contacts on the cetrifugal switch, thus sending power to the motor, allowing it to run. I guess you have done that.
The second lead out of the timer goes to the push to start switch, it then leaves and goes to the centrifugal switch but on the power side, so it is directly connected to the main winding in the motor.
That is why when you press the press to start switch, the motor runs, and if held in it will continue to run.
In fact, at this point, the motor had 2 sources of power, either of which can run the motor.
Thus releasing the push to start switch doesn't matter, since it runs off the other source.
Possibilities.
The centrifugal switch is not wired right. Please recheck. (or the motor was bad out of the box. Happens).
The push to start switch is bad, and needs replaced.
Or, the wiring going to or leaving the push to start switch has broken or making a bad connection.
Lastley, I said the power comes out of the timer and splits into 2 circuits. Not always true, in some models the timer sends 2 seperate wires out carrying the power, with the possibility the timer could be bad.
Hope this helps.
and thank for using FixYa
Posted on Jan 07, 2010
Testimonial: "Jack was a great help. Really took the time to help me with my problem in depth. Thanks again."
hunter19_46m
  • 7482 Answers
SOURCE: Electric Maytag Dryer Performa: Front loading
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
Jul 14, 2008 | Maytag MED9600S Electric Dryer
Maytag bravos quiet series 300 ran a long time got hot. Now the control panel lights up power button lights up press start button and clicks but dryer will not start
Most likely your thermo-fuse is bad. The fuse is normally located on the blower housing(usually white with 2 wires) You would need a continuity tester to confirm that it has continuity. It sometimes fails do to over load of clothing, vent clog, bad cycle thermostat, or failure to clean lint screen. If this is a computer controlled model the heater relay could also be bad. and caused the fuse to fail.
Dec 27, 2014 | Maytag Dryers
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
Maytag Model SDG3606AWW slow to start, shrieks when running
T"he sound you are hearing is coming from the blower wheel.This is located in the front of the machine and can be accessed by removing the front of the machine, Getting the front off varies machine to machine, Once the front is off, you'll see the blower wheel in the front, and once again some models you may have to remove exhaust vent, in others just the cover of the blower wheel. This is an easy repair, no doubt. The part number is 56000
Jun 03, 2012 | Maytag Dryers
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
All the lights on front panel on my frigidaire FEQBB30DS0 dryer
Sounds like one of the buttons is stuck. You may have to replace the touch keys panel
Sep 04, 2009 | Dryers
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Maytag Epic Front Load Dryer
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
Jan 26, 2008 | Maytag MED9600S Electric Dryer
Maytag MED9700S Electric Dryer Logo
1,275 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
