Question about SmartDisk 40GB - 4200rpm - 40MBps - IEEE 1394a - External FireLite from is a portable external hard ... FireWire 400 Hard Drive
Miising power supply
My FireLite Model # USBFL40P uses an external power supply, I lost it. Can some one tell me what kind of power supply do I need to replace it, is it 5V, 9V or what?
Thanks,
Alejandro
    Problem Solver:
  • 14 Answers
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Posted on Feb 27, 2009
  • Tom Britton Jun 20, 2012
    It's good to know the part number but where can the part be purchased?
Need to know what AC adapter to use with my Firelite. Have a number of AC adapters but not sure which one goes with my unit
First ..this is an usb disk ..and usually it does not need an external power supply but in special cases when it is plugged in something it can not sustain it ..i understood it does have a power supply plug ..but ..I repeat ..it should work on the usb alone ..and get the power from it ..
If you experience some issues and need to know if ti will work when you power it external ..the values are written on the back of teh drive ..or near the plug ..You will only need to have the right jack ..and the voltage to match ..beware of any higher voltage ..it may damage it right the way ..
Dec 28, 2011 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Im trying to access my firelite external hard drive (model USBFLB80) that has been sitting around unused for a while. I have a new computer, which is a mac, now and only used it with a windows pc before. I...
Hi
A USBFLB80 is not a hard disk controller, it's an external USB hard drive and does not require any driver when used in Windows ME/2000/XP. This device is plug and play in Windows XP providing you have a working usb port to plug it into.
May 29, 2011 | FireLite (USBFLB80) Hard Drive
Not sure how to use it
First go to this link and download the manual, and software. It explains everything very well. Basically it is very similar to a very big USB jump-drive, or flash drive, with more "bells and whistles"
http://www.verbatim.com/support/support.cfm?open=Downloads
Hope this helps. Any questions please contact me.
AAirwolf
AAirwolf@Comcast.Net
Jul 22, 2010 | FireLite (USBFLB80) Hard Drive
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
What kind of external power supply does it need if
Portable HDDs normally have a dual cable USB with the thicker cable being the power and data and the thinner one power only. Many manufacturers now make PSUs with USB sockets
Mar 06, 2010 | FireLite (USBFLB80) Hard Drive
Firelite usbflb40-c USB device exceeded power limits of hub port
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Jul 31, 2009 | SmartDisk FireLite 20 GB Hard Drive
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Center Pin External Power Polarity
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Jan 21, 2008 | FireLite (USBFLB80) Hard Drive
SmartDisk 40GB - 4200rpm - 40MBps - IEEE 1394a - External FireLite from is a portable external hard ... FireWire 400 Hard Drive Logo
304 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
