Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Won't work right
I ran the disk have it hooked up but nothing wotks right on it I tried to copy pictyres to my computer nothing
    President:
  • 2,692 Answers
Does the disk that you used to install with specify that it is for the specific version of windows that you are using? If not , It will not work.Ddownload the correct driver for the version of windows being used and the printer using the driver not the disk.
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Posted on Mar 07, 2009
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
My emachines e350 won`t turn on it alweys says No bootable device--Please restart systam and I do that and it says it again
Check that you have not left a non-bootable CD, diskette, or DVD in the drives of your PC, nor have any USB devices plugged in that the system might be looking to try to boot from.
If the above check is clear, then go into the BIOS settings and check that your internal hard disk drive is set as the first boot device or is ahead of any other disk drives you may have installed.
You cannot connect computers to each other by just using a standard USB cable - it doesn't work that way.
If you still cannot boot from your internal hard drive, then you should consider downloading a copy of Hiren's Boot CD (which is a CD .ISO image) then burn this to a real CD and try booting from that media - you may have to select the CD as a boot device in your BIOS or if you get a boot options menu.
If you can boot the Hiren's CD ok, then your internal hard disk may have failed - you can test this with the DOS Programs of the Hiren's CD by selecting Hard Disk tools then selecting HDAT2 which will try to find any installed hard disks then allow you to test these and repair problems if possible.
Jan 01, 2012 | Computers & Internet
My laptop has a strange problem. CDs and DVDs do work fine but when I put in 1 particular DVD the drive does not recognise it. The DVD is working on other computers though. I have an ACER ASPIRE 6530 ,...
This is not uncommon at all.
There are slight variations in drives and the tracks of data on the disks are extremely small. A disk may be off a tiny amount and may not work in some drives but will work in others. This seems to be particularly true of user recorded disks.
One thing that sometimes works is to make a copy of the disk. Even making a copy with a drive that won't read it normally may sometimes work. The disk copying software will usually warn you and refuse to try if it really can't read it. Try copying it in another machine, that should solve the problem.
HTH
Jun 16, 2011 | Computers & Internet
I used Diskwarrior on my Mac external hard drive got error 0,1613
You should STOP trying to run Disk Warrior. You drive is probably failing. What you need to do is boot the mac into Target mode and hook it up to another machine, copy off your important files ( start with the critical stuff first ).
Then after you've got everything, format and reinstall the OS. If you've got a copy of DriveGenius I' d do a hardware scan on the drive. It's probably toast.
Apr 04, 2010 | Computers & Internet
WD My Book Studio Ed. (Mac) - 2TB - stopped working for no reason
plug your drive in to your computer, right click
on my computer and bring up disk manager,
open disk manager and see if your wd drive
shows up. then reinitialize the drive and this
will hopefully solve your problem.
Aug 21, 2009 | Western Digital My Book Home Edition 500...
Hook up to usb port, nothing happens
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Mar 24, 2009 | Nikon COOLPIX L18 Digital Camera
Can't access files on external hard drive
Hi All had the same prob with my external drive and used a program called Easy recovery professional it worked for me .hope this works
Dec 27, 2008 | Western Digital Passport WDXML800UE...
Computer keeps on telling me "please insert a disk into drive E:"
try to rerfresh on MY COMPUTER then it will appear on E, if it won't open, right click then Explore.
May 07, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Unable to download pictures from camera to pc
i cant upload pic to my comuter from my camra when i incert the memory card it sayys incerst drive F?
what do i do?
Dec 15, 2007 | Konica Revio KD-310Z Digital Camera
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
