Question about D-Link AirPlus DI-524 Wireless Router
Cant connect to wireless without rebooting my router
I have a d-link di-514 router that my desktop connects directly to and it works fine but when I connect any wireless device they connect fine the first time but if I disconnect and then try to reconnect it wont go through. my laptop just keeps trying to connect and after a few minutes gives up. I also have a psp that does the same thing. Any wireless device can connect once but any subsequent tries to connect are denied.
  • Hank Terrebrood Mar 15, 2009
    Can connnect fine via cable, and can connect once wirelessly. If I must reconnect or add another wireless connection the wireless stops responding. It also will ocassionally dissapear from available wireless network search. It is less than 10 feet from my 2 laptops.
    Have changed the channel, tried differrent security types...nothing helps.
    Novelist:
    Habit-Forming:
  • D-Link Expert
  • 199 Answers
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
This many times fixes issues like your described.
Posted on Jan 06, 2017
De Guyver
  • 123 Answers
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
Posted on Feb 16, 2006
De Guyver
  • 123 Answers
SOURCE: lost cd to d-link model DI-514
It's a B:1
Posted on May 30, 2008
  • 27 Answers
SOURCE: putting a password on my D-Link DI-514 Wireless router
You can add passwords in the Web Management page. If this is the default settings Type http://192.168.0.1 in your browser's URL interface. Or you can also use the Software Provided
Posted on Jul 12, 2008
  • 16 Answers
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Posted on Aug 10, 2008
Connection to I Pod touch from PC desktop computer Unable to connect
1.- You must verify that the desktop computer works without problem in wireless way with the D-Link device.-
2.- The I Pod touch device is an external unit to the desktop computer, so you have be shure of the first condition.-
3.- If the destop computer don`t work in wireless conditions, the fail is in the configuration of the LanWireless, you must check both, D-Link device and computer configurations.-
4.- If the computer works ok, the problem is only in the I Pod touch only.- You muts to check fisical connections and I Pod hardware.-
Sep 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
I can get on the internet if I connect directly from my cable modem to my desktop, but not if I connect through my dlink di-512 ethernet port, however the wireless works ok on my laptop with the same...
1. check the status lights on the router if they flashing you have lost connectivity.
2.unplug or press the reset button on the back of the router hold in. this will reset the router
3. reboot the PC. this will reset the PC.
4.when connected you will have to update the firmware.
I looked at the manufacturer's site and this router is discontinued but there are resources to troubleshoot this issue
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
go to this page above to do further troubleshooting.
Feb 20, 2010 | D-Link DI 514 Wireless Router (DI-514)
Connection and wireless network with DI-514 disappeared
there is a very small reset button on the unit. Press it and hold it for 5 seconds. This will reset it to the factory specs. Then proceed to set it up like you did when you got it new.
May 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
Modem and wireless not talking
If u r inside a wireless network and internet is ok, u will able to ping both the wireless router gateway and modem gateway. If u cant ping the modem gateway, u can try connect the modem directly to your pc, and test again. U need to make sure the modem is OK, and able to connect to internet. Then only u move to check router. This is due to very often internet access having problem.
Mar 10, 2009 | D-Link DI 514 Wireless Router (DI-514)
Cant connect to my router through laptops built in wireless/ps3
restart your wireless router and try again...
check the settings on your wifi router and on your desktop....
Jan 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus DI-524 Wireless Router Logo
257 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
