Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Futura ce-200 "parked" in wrong position.
I attempted to embroider a design that whas saved, and had been used previously. The machine just did a zigzag pattern and the embroidery carriage with the small hoop attached moved to the top of the carriage vs. the bottom. Now it stays there and makes a grinding noise when the machine is turned on with or without the small hoop. Is there a reset button or something that can help?
  • Anonymous Mar 15, 2014
    janome mc11000 SE carriage embroiders in wrong positions
  • Anonymous Mar 20, 2014
    carriage won't move when I turn the machine on
  • 23 Answers
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Posted on Feb 27, 2009
Futura 150. Using autopunch. The machine does some of the
have you tried changing the needle?
it could be a part of the computer is mal-fuctioning
it could be out of time
it needs to be serviced to find out what's wrong with it.
Mar 22, 2012 | Singer CE-200 Quantum Futura Computerized...
Does the futura software from compucon allow you to wind the design forward so you can upload the design to the machine, and can continue embroidering the design to complete it. Reason why is had to...
You can skip color blocks that you have already embroidered. When you get to the one you were working on when the machine was turned off, send it to the machine and use the needle down button to advance the design to the point when you stopped. Then you can hit the green button and proceed.
Dec 04, 2011 | Singer CE-200 Quantum Futura Computerized...
My futura ce 200 quantum embroidery machine is all set up to embroider and the green light is on when I push to start nothing happens. When I push the back stich it goes back to the orginal position and...
Change the fuse in the plug failing that it could be the inline fuse inside the machine normally near where you plug the lead in, if youcan get to that it is a matter of changing it, and the Hoop must be detachedwhen powering on! Otherwise it will not start. Hope this will help you. Good Luck.
Jul 20, 2011 | Singer CE-200 Quantum Futura Computerized...
When I try to send a design to my Quantum Futura CE-200 I get a message that a transmission to machine is still pending, and I must cancel the pending design before I can continue. I have not used the...
Go to futura-support.com Go to FAQ and go to #7. Follow the procedure EXACTLY, save one thing that is not on there. BEFORE you do anything, make double-sure your machine is set for embroidery (E) and not sewing (S). Even if you follow the procedure exactly, if your machine is on 'S' and not 'E', you will continue to get the 'transmission' message.
May 23, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Can't seem to embroider
brothers frame is much smaller I think 4 x 4. I have futura 200. found this to happen at first but now now. Make sure when threading that you floss the thread through the top part, it has plastic over it. The thread must fit properly in this part. (flossing means to run back and forth a couple of times holding thread tightly). Also, hold the 2 thread ends when you first start to embroider. Hope this helps
Apr 12, 2008 | Singer CE-200 Quantum Futura Computerized...
Needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Dec 22, 2007 | Singer CE-200 Quantum Futura Computerized...
Bobbin Thread
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
150 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
