Got a missil mp4 player can't figure out how to load music??
  • rharpell Feb 27, 2009
    ok i understand what u mean, but when i plug in the player to the computer, notin shows up on the computer?? I have a lot of songs on limewire that i want to put on but with the mp4 missil only came one disk and it says i don't have to load it if i have higer than windows2000, which i do so i'm not sure how it is suppose to load with out software?? i think it might have been a waste of money
  • Anonymous May 01, 2009
    I find it very strange that an operating manual describes how to play the unit, before mentioning how to load the mp3's onto the unit. Generally, items of this nature simply ask to insert a disk which automatically start loading the necessary software to run the player simply by putting the disk into the computer...not this item though. Furthermore, the instruction manual alludes to converting AMV files first before mentioning how to load mp3's onto the player which to me is a red flag that the instructions were never provided.
    Scholar:
  • 106 Answers
These made in China MP4 players are quite budget ... however, I've managed to get mine working just fine. Just follow these steps:
1. Charge the unit. (These things come with a dead power supply, so you'll have to to charge it with the provided USB cable... or any cable such as one that works with a camera. you'll not be able to load it or turn it on until this has been done. 3 hours later your computer will detect new hardware (USB mass storage device) and install the appropriate drivers.
2. Loading MP3's... there are 2 ways to go about this...
a) If you have the latest Windows media player click on the SYNC tab and follow the directions.
b) Open "My Computer" you should be able to see a new drive (probably E: F: or G:) double click to expand it, you should see a bunch of folders, simply drag and drop your MP3s to the Music folder.
3. Converting and Loading Video: The included program that comes with these cheap-*** players is a bag of $#@! so dont even bother with it.
The best program to convert videos to work on this thing can be found HERE
-Pick the first one (note:this file is zipped so will need to extract it),
pick up a trial version of WinRar HERE
-Once extracted, go ahead and run the program...click ADD
Choose your input file, and output path,
You will need to know the resolution of your screen. Under Player type, choose SUNPLUS AVI and select the video resolution of your Missil, 30 frames/sec and the best sound/video quality and hit start.
- this process takes a while (30-60 min) depending on file size.
- Once complete, simply drag and drop (cut and paste) the converted file to to the VIDEO folder on the players drive.
3. Finally disconnect the player from the computer, it will say "please wait.. building playlist" once this is done you're good to go
I hope this has been helpful... and please... dont forget to rate this solution.
Jermzii
Posted on May 02, 2009
  • 1,800 Answers
Copy paste muic or drag it to the dirctory F.
Posted on Feb 27, 2009
  • Jalal Sordo
    Jalal Sordo Feb 27, 2009
    copy paste muic or drag it to the dirctory F.
  • Jalal Sordo
    as long as it is not detecatble by ur compter that means its defective also try a Another USB cord.
    Problem Solver:
  • 14 Answers
Hi There,                You must charge the device fully first by attaching it to your computer by your usb cable it came with for 4 hours. The unplug it and shut it off (your device). Once it off replug it into your usb  cable and to your computer again and the plug and play on your computer because it a higher window software should automatically identify the device. The all you do so drop and drag your music in the right folder in your device.
Posted on May 24, 2009
OK, this is a is the best explanation I can give
1 read manual carefully then install software
2 charge miss (missile)
3 unplug miss from computer (comp) and turn miss on - there should be folders showing up on miss (at least the music folder)
4 record all the folder names exactly as shown on the miss (use rt key to go through all the list)
5 power off miss and then connect to comp, then power up miss again
6 a new drive with folders (at least the music folder) should show up on comp
7 if the folders recorded carefully above don't exist on comp, then create them
---- I found I could at least copy music and pics (video after conversion) - and it worked
last response - good luck
Posted on Apr 29, 2009
2 Suggested Answers
Jermzii
  • 106 Answers
SOURCE: I got a missil gl-1502
These made in China MP4 players are quite budget ... however,I've managed to get mine working just fine. Just follow these steps:
1.Charge the unit. (These things come with a dead power supply, soyou'llhave to to charge it with the provided USB cable... or any cable such asone that works with a camera. you'll not be able to load it orturn iton until this has been done. 3 hours later your computer willdetect newhardware (USB mass storage device) and install the appropriate drivers.
b)Open "My Computer" you should be able to see a new drive (probably E: F:or G:) double click to expand it, you should see a bunch of folders,simply drag and drop your MP3s to the Music folder.
3.Converting and Loading Video: The included program that comes withthesecheap-*** players is a bag of $#@! so dont even bother with it.
Youwill need to know the resolution of your screen. Under Playertype,choose SUNPLUS AVI and select the video resolution of your Missil, 30frames/sec and the best sound/video quality and hit start.
3.Finally disconnect the player from the computer, it will say"pleasewait.. building playlist" once this is done you're good to go
Jermzii
Missil digital MP4 Player manual
i have just get the missil mp4 and i dont now howto work it
Dec 29, 2010 | Audio Players & Recorders
Missil Digital MP4 Player
HOW CAN I FIND STRAGENTH IN POKEMON PLATINUM VERSION?
Mar 17, 2010 | Generic Memory Missile Launcher
Might buy Missil 8GB MP4 touch screen Any Suggestions?
Missil multimedia prpducts tend to have problems with the headphone jacks, I've had numerous MP3/MP4 players made by them, including the non-touch screen version of the one you're considering buying, and of all the ones I've had (probably around 15 different items from Missil), about 1 in 3 had issues with the headphone jack disconnecting from the circuit board inside.
That being said, a friend of mine has the touch screen one, and granted you have decent headphones, it has amazing sound quality for the price and all around is on par with anything of the iPod series, other than in reliability. Just make sure you get the longest warranty you can afford with it, just in case. When buying cheap electronics, the product itself will usually defect before it breaks from the users flaws.
Mar 14, 2010 | Generic Memory Missile Launcher
Missil A940LCD2PK mp3 player turning off
I don't know if mine is a Missil brand, but the pix of the Missil A940LCD2PK look exactly like my no-name Chinese MP3 clip-on player. I am experiencing exactly the same problem. My firmware is 2208/06/12 V1.05. Everything else works as it should except, of course, music mode. The directory has "root" and a single "voice" folder for voice recordings. Is music mode looking for a folder? Is there some way to correct or upgrade firmware?
Feb 18, 2010 | Audio Players & Recorders
I can't figure our how to get internet on my gl-15052 mp3 player
O lol i bought my GL 15052 yesterday 2 n there is no way that u could get internet. XS cargo! i bought it from the same place n the employee was crazy because it impossible to get internet on MP4s
May 01, 2009 | Audio Players & Recorders
The missil disk i got won't setup in my computer
Dont even bother with that disk, What is the model number of your player?
-I'll be able help you get video on it, I just need to know the resolution of the screen.
-as for music, there are 2 ways to go about loading your songs...
1. use windows media player, click on the sync tab, setup your device, check the songs you want to load and then click start sync.
2. open my computer, your device will show up as USB mass storage device, double click that and simply drag and drop your mp3 files into the music folder
Apr 16, 2009 | Network Computing Devices (NSH800S/A)...
Mp4 player hourglass Missil
Press the reset /mic with pin tell me if this works for you.
Jan 02, 2009 | Generic Memory Missile Launcher
Trying to download to new missil mp4 mp3player
You can load any file into this thing just make sure that you put your MP3's into the music folder heres a tutorial on how to get the most out of this xs cargo knock off.
These made in China MP4 players are quite budget ... however, I'vemanaged to get mine working just fine. Just follow these steps:
1. Charge the unit. (These things come with a dead power supply, soyou'll have to to charge it with the provided USB cable... or any cablesuch as one that works with a camera. you'll not be able to load it orturn it on until this has been done. 3 hours later your computer willdetect new hardware (USB mass storage device) and install theappropriate drivers.
b) Open "My Computer" you should be able to see a new drive (probablyE: F: or G:) double click to expand it, you should see a bunch offolders, simply drag and drop your MP3s to the Music folder.
3. Converting and Loading Video: The included program that comes withthese cheap-*** players is a bag of $#@! so dont even bother with it.
You will need to know the resolution of your screen. Under Playertype, choose SUNPLUS AVI and select the video resolution of yourMissil, 30 frames/sec and the best sound/video quality and hit start.
3. Finally disconnect the player from the computer, it will say "pleasewait.. building playlist" once this is done you're good to go
Jermzii
Dec 26, 2008 | Generic Memory Missile Launcher
MP4 Missil not working
I used real player to get songs on my missil sd-2415 MP4 player. You need to use the driver disk it came with to get it to work. Once you've used the driver you should be able to just plug your player into the computer via the USB cord, open real player Version 11, compatible with Windows XP, although the driver says win 98, it worked fine with my Windows Xp. Nothing really comes up once thr driver has been downloaded, so don't get confused, just follow the driver install wizard and it should be fine. Then on Real player just click on removable disk or player not sure of the exact wording but it's removable somthing the just drag and drop or click to move music from your playlist onto the player.
I had to fiddle around with this player a bit because the instructions are VERY LIMITED! that's putting it mildy but hey it is what it is. This little player is quite neat once you figure out it's little quirks! Good luck!
Dec 26, 2008 | Network Computing Devices (NSH800S/A)...
917 people viewed this question
 Grubhead
Grubhead
