Question about IBM ThinkPad T30 2366 Notebook
Battery won't charge
I am using an IBM-T30. I am running Windows XP SP2. My computer is basically working fine except for one thing. The battery won't charge. The driver that is responsible for that is working fine. I assume that the Ac adapter is working fine seeing that it is powering my machine right now. Does anyone at fixya have any solutions.
Note: When I place the battery in the computer, the battery icon on the keyboard starts flashing. This should mean that the battery is charging but it isn't. Help.....Please??
  • Bum Bam Feb 27, 2009
    When I looked in the power section everything was working fine. Can you offer any other solutions?
    Additionally, I should add that one day I was using my computer and it suddenly froze. I turned it off. When I tried to start it up it gave me an "1802" error message about the PCI card. The laptop was inactive for about 2 months then I removed the PCI card and placed in back in the computer. After that, the battery hasn't charged once. The battery used to charge up well before the PCI incident. Any solutions??
  • 80 Answers
Trying seeing the status of it in the bios! that usually tells you if the battery is faulty
it might make you caliibrate the battery to!
or it might not see it all which means its bad!
Posted on Feb 27, 2009
Dell Inspiron e1405 Laptop. Why won't the battery charge?
If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that
the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by
using Device Manager
1.Open Device Manager
Right click on My Computer->select Properties->click Hardware tab->click Device Manager
or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
2.Expand the Batteries category
3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select
Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes.
Please let me know if it's works or not and thanks for using fixya
Sep 03, 2012 | IBM ThinkPad Computers & Internet
Ok i have a Ibm thinkpad and my charger is stuck on green battery but it wont charge at all. It was working earlier but i turned of the computer the wrong way by holding the power button since i was in a...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 18, 2011 | IBM ThinkPad T30 2366 Notebook
My ibm laptop battery ran all the way down. now it won,t restart
I assume you have put the battery on charge for a while first and you are trying to restart it with mains power connected.
Try removing the battery (disconnect power first) Then reconnect power and try restart.
If that does not work you have a hardware fault.
If it does work without the battery, the battery is faulty and will need to be replaced.
Mar 06, 2010 | IBM ThinkPad T30 2366 Notebook
Battery light yellow won't come
allow battery to complete charge (green lite)
Or change battery if chrge not completing.
(check your AC charger)
Jan 11, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad t30 will not start
You should charge the battery longer about four hours. Then the light should be green. Try. If that don't work disconnect the battery and check for anything. Connect your battery again and take a look. If it still isn't functioning please let me know.
Dec 25, 2008 | IBM ThinkPad T30 2366 Notebook
Laptop will not run while plug into the electrical system
Worst case is you need a another motherboard because the power supply unit and charging unit are on the motherboard. Then again it could be the DC power jack on the motherboard is loose and needs replacing. The website below is a link to a ebay site that sells these power jacks.
http://cgi.ebay.com/IBM-Thinkpad-T30-T30p-DC-power-jack_W0QQitemZ200216009749QQihZ010QQcategoryZ158847QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Also is an ebay site for T30 motherboards.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=t30+motherboard
If your good with tools you can replace these parts yourself. Below is the IBM website where you can download the service manual in pdf.format and fix it yourself without taking it to a computer repair shop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42308
If this helps, Please leave a positive rating.
Thanks,
Ray
May 14, 2008 | Computers & Internet
T30 2366 8GA After removing AC Adaptor battery icon shows Charging and working on AC
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
May 13, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30. Battery will not charge.
if your laptop is working fine , plugged in the power, you are hving a problem with the battery pack. If you recently bought this, contact the resseler to replace the pack.
May 02, 2008 | IBM ThinkPad T30 2366 Notebook
IBM t30 battery does not charge
The problem could be the internal battery charger board ( a small daughter board that plugs in the the motherboard) has gone bad. You can check out this site to: http://www.ibm.com/support/us/en/. Ray
Jun 20, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
172 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
