Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
My Maytag Neptune fnt loader Model# MAH8700AWW Ser# 12227145GR
Is leaking an excessive amount of water at the bottom of the washer after the completion of the cycle. Please give me some advise to correct this problem.
  • Anonymous Apr 14, 2009
    Mine leaks water too...makes me sick...I bought a "good" one so I wouldn't have these problems
  • todd548 May 11, 2010
    My washer (same model) is now doing that exact same thing, and today it sounded like one of the pumps started "moaning". Did you find a resolution to your problem?
I have the same problem. The technician seems to think it could be the water is not emptying during cycles. It keeps adding water as the cycles continue and therefore over flowing the tube when it spin. He thinks it could be a water level sensor. Not sure at this point.
Posted on Mar 05, 2009
My maytag neptune washer front loader -the water will not go into washer when it is turned on the serial # is S1101 5853GR and the model 3is MAH8700AWW
First thing I'd check is connections at machine where hoses attach. Shut off water and remove and inspect little screen like filter to trap dirt at machine, to make sure they are not plugged up. Is it happening on both cold and hot?
Jan 26, 2012 | Washing Machines
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune fnt loader Model# MAH9700AWW
I have a Maytag neptune mah8700aww
With mine the large grey rubber seal that seals at door slipped off! When this happens if you do not put back on correctly it will leak or even poor out the front center bottom of the door! My husband fixed it. But it still leaked really bad! I just took a couple of min. to refit the seal and it does not leak at all now! maybe your seal is not placed around the edge correctly! as it is easy to place it wrong! good luck!! keep my email address if I was helpfull!! We can always share problems and solutions for our neptunes in the future ! good luck
Anne Marie
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
360 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
