Yes but maybe it will not last very long. Utilitec 0155671 is indoor timer with 2 grounded outlets. Indoor timers will work outdoors until they gets wet from rain, wet from evening dew, or overheated from exposure to sun. http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
If you have fully charged the device with the power cable and it still will not turn on, it is likely that the battery is no longer holding a charge. You would have to contact Sylvania to ask about battery replaement, but it may be cheaper to purchase a new device.
Just get this tool to help you. 1. load your file to Video Sharer 2. choose mp3 format 3. click" convert" button. Then you will get the right format. Here is the tool for you: http://www.asharer.com/download-video-sharer
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
Things I would check are ... Power at the outlet? Is the charger ON? Is there a fuse or circuit breaker involved? Are you certain it was plugged in (charger to charge port)? Have you noticed any deterioration in its operation recently?
