Question about Slider 18K Select Plus Fifth Wheel Trailer Hitch with by Draw Tite, Reese and Hidden Hitch
Fifth wheel slack
I have a 2002 36 foot terry EXL fifthwheel. I recently started having slack in the front to back motion of the hitch and pin connection. When you stop the trailer comes forward by 1/8", and when you take off its the opposite, by 1/8". what do I do to stop this problem. the fifth wheel hitch in the truck is not a slider, and I keep it oiled and inside when not used.
Owners manual for 14 foot weekender travel trailer
check tongue weight on unit and check load rating on hitch or get professional advise that I suggest
Jul 16, 2017 | RVs
Where is the VIN number on a fleetwood terry resort 1991 fifth wheel
Dirrerent make but mine is stamped into the side of the 5th wheel hitch main frame
May 25, 2017 | RVs
What size gooseneck hitch do i buy to pull my 36 ft dutchman colorado fifth wheel
depending on where you buy your hitch, a salesperson versus online. but if you get a chance to stop by a camper place and ask what size they recommend. There are a multitude of sizes and styles. like I have a 1 ton dually with the pin in the bed of the truck while my international 4700 has a small semi style plate with the ball ( kingpin) on the trailer. best to see what they would recommend. no obligation and information is free.
Nov 16, 2015 | 1059 B&W Turnover Ball Gooseneck Hitch...
How far back from the cab on a 2009 silverado short bed do i install hitch?
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 15, 2011 | Chevrolet 2500 Cars & Trucks
My 16k slider hitch does not slide. the handle moves from maneuvering to tow, but the hitch won't slide. It's like it is jammed in the tow position. Any answers?? THANKS
Most "Sliding" Cequent products won't slide by hand. You will need the full weight of a trailer in order to do so. All CURT rollers glide with ease.
Apr 13, 2011 | Slider 18K Select Plus Fifth Wheel Trailer...
I have a 2001 expedition E/B a small pin feel from my steering column and I know it need to go back in the gear shift handle since it is real sloppy now. I aslo had a heavy piece of flat like metal fall...
sounds like the pin has worked out of your tilt system. you would have to remove the steering wheel and signal switch. over time the bolts back out and create slack therefore allows the pins to fall out.
Apr 01, 2010 | 2000 Ford Expedition
What grade bolts do i use for my fifth wheel hitch I need the bolt grade length and size how many and how many washers
I can only answer one part of this because I dont know your hitch alway use grade 8 bolt in a hitch,sorry I could not have been more help
Sep 19, 2009 | 2005 Chevrolet Silverado 2500HD 2WD
When I try to hook up my camper it takes a few tries before my hitch locks in place. i have to work & work on it before it latches.
Lubricate the latch mechanism with lithium grease spray. Make sure the latch is fully open and the hitch is fully seated. If there is rearward pressure on the mechanism it won't latch.
Sep 05, 2009 | Slider 18K Select Plus Fifth Wheel Trailer...
Slider 18K Select Plus Fifth Wheel Trailer Hitch with  by Draw Tite, Reese and Hidden Hitch Logo
193 people viewed this question
Top Slider Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Slider Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
